Updated on 2026-09-18 GMT+08:00
OBS Link Parameters
When connecting CDM to the destination OBS bucket, you need to add read and write permissions to the destination OBS bucket, but authentication files are not required.
  • If the CDM cluster and OBS bucket are not in the same region, the CDM cluster cannot access the OBS bucket.
  • Do not change the password or user when the job is running. If you do so, the password will not take effect immediately and the job will fail.
When connecting CDM to OBS, configure the parameters as described in Table 1.
Table 1 Parameter description
Example Value
Name
Link name, which should be defined based on the data source type, so it is easier to remember what the link is for
obs_link
OBS Endpoint
An endpoint is the request address for calling an API. Endpoints vary depending on services and regions. You can obtain the OBS bucket endpoint by either of the following means:
To obtain the endpoint of an OBS bucket, go to the OBS console and click the bucket name to go to its details page.
obs.myregion.mycloud.com
Port
Data transmission port. The HTTPS port number is 443 and the HTTP port number is 80.
443
OBS Bucket Type
Select a value from the drop-down list, generally, Object Storage.
Object Storage
AK
AK and SK are used to log in to the OBS server.
You need to create an access key for the current account and obtain an AK/SK pair.
To obtain an access key, perform the following steps:
  1. Log in to the management console, move the cursor to the username in the upper right corner, and select My Credentials from the drop-down list.
  2. On the My Credentials page, choose Access Keys, and click Create Access Key. See Figure 1.
    Figure 1 Clicking Create Access Key
  3. Click OK and save the access key file as prompted. The access key file will be saved to your browser's configured download location. Open the credentials.csv file to view Access Key Id and Secret Access Key.
    • Only two access keys can be added for each user.
    • To ensure access key security, the access key is automatically downloaded only when it is generated for the first time and cannot be obtained from the management console later. Keep them properly.
SK
Link Attributes
(Optional) Displayed when you click Show Advanced Attributes.
You can click Add to add custom attributes for the link.
Currently, only the file.gen.identifier.only.when.data.migrate attribute can be configured. This attribute is used together with the Job Success Marker File parameter at the destination to specify whether to generate a success marker file.
The following are some examples:
  • If the value of this attribute is true, and the Job Success Marker File parameter is configured at the destination, the system checks whether data has been generated.
    • If there is data, a marker file will be generated.
    • If there is no data, no marker file will be generated.
  • If the value of this attribute is false, and the Job Success Marker File parameter is configured at the destination, the system generates a marker file without checking whether there is data.
