On this page
Show all
PostgreSQL/SQLServer Link Parameters
Updated on 2024-11-20 GMT+08:00
Table 1 lists the parameters for creating a link to PostgreSQL/SQLServer. KingBase and GaussDB can be connected through the PostgreSQL connector. The source and destination data sources supported by migration jobs are the same as those for PostgreSQL..
Do not change the password or user when the job is running. If you do so, the password will not take effect immediately and the job will fail.
Table 1 PostgreSQL/SQLServer link parameters
Example Value
Name
Link name, which should be defined based on the data source type, so it is easier to remember what the link is for
sql_link
Database Server
IP address or domain name of the database to connect
Click Select next to the text box to obtain the list of instances.
192.168.0.1
Port
Port of the database to connect
The port number varies depending on the database. Examples:
Default port of SQL Server: 1433
Default port of PostgreSQL: 5432
Database Name
Name of the database to connect
dbname
Username
Username used for accessing the database This account must have the permissions required to read and write data tables and metadata.
cdm
Password
Password of the user
Use Agent
The agent function will be unavailable soon and does not need to be configured.
Agent
Driver Class Name
Class name of the uploaded driver
Select org.postgresql.Driver or com.kingbase8.Driver.
Reference Sign
(Optional) Delimiter between the names of the referenced tables or columns. For details, see the product documentation of the corresponding database.
Driver Version
Different types of relational databases adapt to different drivers. For details, see How Do I Obtain a Driver?
Fetch Size
(Optional) Displayed when you click Show Advanced Attributes.
Number of rows obtained by each request. Set this parameter based on the data source and the job's data size. If the value is either too large or too small, the job may run for a long time.
1000
Commit Size
Number of records submitted each time. Set this parameter based on the destination and data size of the job. If the value is too large or too small, the job execution time may be affected.
10000
SSL Encryption
Whether to connect to the database in SSL mode
Yes
Link Attributes
(Optional) Click Add to add the JDBC connector attributes of multiple specified data sources. For details, see the JDBC connector document of the corresponding database.
The following are some examples:
  • connectTimeout=60 and socketTimeout=300: When a large amount of data needs to be migrated or the entire table is retrieved using query statements, the migration fails due to connection timeout. In this case, you can customize the connection timeout interval (s) and socket timeout interval (s) to prevent failures caused by timeout.
  • useCursorFetch=false: By default, useCursorFetch is enabled, indicating that the JDBC connector communicates with relational databases using a binary protocol. Some third-party systems may have compatibility issues, causing migration time conversion errors. In this case, you can disable this function.
  • trustServerCertificate=true: A PKIX error may be reported during the creation of a secure connection. You are advised to set this parameter to true.
sslmode=require
Link Secret Attributes
Custom secret attributes of the link
sk=09fUgD5WOF1L6f
