Searching for SSL Certificates by Tag
This section describes how to search for an SSL certificate by tag in a project on the SCM console.
A tag has been added.
At most 20 tags can be added for one search. If multiple tags are added, SSL certificates that meet all search criteria will be displayed.
- Log in to the CCM console.
- In the navigation pane on the left, choose SSL Certificate Manager > SSL Certificates.
- Click the search box and enter the tag key and tag value to search for the resource. SSL certificates that meet the search criteria are displayed.
Figure 1 Search result
- At most 20 tags can be added for one search. If multiple tags are added, SSL certificates that meet all search criteria will be displayed.
- If you want to delete an added tag from the search criteria, click
next to the tag.
