Updated on 2025-09-29 GMT+08:00
Disabling Auto-Rotation for an SSL Certificate
This topic describes how to disable certificate auto-rotation.
You have enabled auto-rotation for SSL certificates deployed on Huawei Cloud services.
  1. Log in to the CCM console.
  2. In the navigation pane on the left, choose SSL Certificate Manager > SSL Certificates.
  3. Locate the row containing the certificate you want to deploy on other cloud product, and click Deploy in the Operation to go to the certificate deployment details page.
    Figure 1 Deploying a certificate
  4. In the resource list, select the domain name for which you want to disable auto-rotation and click Disable Auto-Rotation in the Operation column.
    Figure 2 Disable Auto-Rotation
  5. If the domain name is no longer listed in the resources with certificate auto-rotation enabled, certificate auto-rotation is disabled for the domain name.
