Deploying an SSL Certificate to CDN
When an SSL certificate is issued, you can deploy it to Huawei Cloud Content Delivery Network (CDN) in just a few clicks. With SSL certificates, data access to your website that uses CDN is more secure.
- You have enabled CDN, added your website to CDN, and configured an SSL certificate for the website in CDN.
If you have not purchased CDN or the domain name you want to use the certificate for has not been added to CDN, deploying the certificate to CDN may fail.
- You have an SSL certificate that is in Issued or Hosted status.
If you select Upload a CSR for CSR when applying for a certificate, the issued certificate cannot be directly deployed to other cloud products through SCM because no private key of the certificate is available on the Huawei cloud. To use a certificate in a cloud product, download the certificate to your local PC first. Then, upload the certificate and private key to the cloud product and complete deployment. Alternatively, upload the private key to the cloud certificate and management service.
Deploying Certificates
- Log in to the CCM console.
- In the navigation pane on the left, choose SSL Certificate Manager > SSL Certificates.
- Locate the row containing the certificate you want to deploy on other cloud products, and click Deploy in the Operation to go to the certificate deployment details page. Figure 1 Deploying a certificate
- On the displayed page, select CDN in the Deployment Details area. Figure 2 Selecting CDN
- Select the domain name you want to deploy the certificate for and click Deploy or Redeploy in the Operation column.
To deploy the certificates for multiple domain names, select all the target domain names and click Batch Update above the domain name list.
- (Optional) If the certificate has been deployed for the current domain name, after you click Redeploy, a dialog box is displayed, indicating that the certificate is deployed .
- In the displayed dialog box, confirm the information. Click Confirm.
After the deployment is successful, a message is displayed, indicating that the deployment is successful. Go to the deployment record page to view the result.
