Help Center/ Cloud Certificate & Manager/ SSL Certificate Manager (SCM) User Guide/ SSL Certificate Sharing/ Updating SSL Certificate Resource Sharing
Updated on 2025-12-29 GMT+08:00
You can update a resource share at any time, including updating its name, description, tags, shared resources, RAM managed permissions, and principals.
- Log in to the CCM console.
- Click
in the upper left corner, choose , and go to the resource access management page. - Choose .
- Select the resource share to be updated and click Edit in the Operation column.
- Update the resource share on the displayed page. You can modify its name, description, tags, and add or delete shared resources.
- After the update is complete, click Next: Associate Permissions in the lower right corner.
- Add or delete the permissions supported by scm:cert. Wait until the update is complete, click Next: Grant Access to Principals.
- On the displayed page, add or delete principals based on your needs. Then, click Next: Confirm in the lower right corner.
- Confirm the configurations and click OK in the lower right corner.
Parent topic: SSL Certificate Sharing
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
