Updated on 2025-12-29 GMT+08:00
Creating SSL Certificate Resource Sharing
To share resources with other accounts, you need to create a resource share first. During the creation, you need to specify resources to be shared, configure permissions, specify users to be shared with, and confirm the configuration.
  1. Log in to the CCM console.
  2. Click in the upper left corner, choose Management & Governance > Resource Access Manager, and go to the resource access management page.
  3. Choose Shared by Me > Resource Shares.
  4. Click Create Resource Share in the upper right corner.
  5. Set resource type to scm:cert, choose the corresponding region, and select SSL certificates to be shared. Click Next: Associate Permissions.
  6. Associate a RAM managed permission with each resource type on the displayed page. Then, click Next: Grant Access to Principals in the lower right corner.
  7. Specify the principals that you want to have access to the resources on the displayed page. Then, click Next: Confirm in the lower right corner.
    Table 1 Description
    Principal Type
  8. Check the configurations and click OK.
    After a resource share is created, RAM initiates a resource sharing invitation to the specified principals. If the principal type is Huawei Cloud account ID, the principals can access and use the shared resources only after they accept the invitation. If the principal type is Organization, the principals in that organization are automatically granted access to the shared resources without the use of invitations.
