Withdrawing an SSL Certificate Application
This topic describes how to withdraw a certificate application.
You can withdraw the application for a certificate whose information is being approved or for which verification by DNS is in progress.
After you withdraw the application, the CA will stop approving its information. Exercise caution with the withdrawal. However, the certificate may have been approved by the CA before you withdraw a certificate application due to a procedure processing cause. In this case, application withdrawal will fail. The withdrawal result is given in the certificate list.
The certificate is in the Pending domain name verification, Pending organization verification, or CA verifying (domain name addition) state.
- You can withdraw a certificate application to modify the domain name or other information as long as the certificate is not issued. Once a certificate is issued, only single-domain and multi-domain certificates can be reissued within the specified period. For more details, see Reissuing an SSL Certificate.
- After a certificate deletion or revocation application is submitted, it cannot be withdrawn.
- After a certificate is withdrawn, the certificate is in the Pending application status. To reissue it, apply for the certificate and complete the domain name ownership and organization verification again.
- Log in to the CCM console.
- In the navigation pane on the left, choose SSL Certificate Manager > SSL Certificates.
- In the row containing the certificate you wish to withdraw your application for, in the Operation column, click Withdraw Application, as shown in Figure 1.
- In the Cancel Application dialog box that is displayed, click Submit. When "Request for canceling the application submitted successfully" is displayed in the upper right corner, the request has been submitted.
At this time, the certificate is in the CA verifying (application withdrawal) state. After the application is withdrawn successfully, the certificate status changes to Pending application.
Other Operations
After the certificate status changes to Pending application, you can then apply for a certificate again. For details, see Submitting an SSL Certificate Application to the CA.
