Updated on 2025-10-31 GMT+08:00
Increasing Reserved System Overhead
For pods running on CCI 2.0, the OS and CCI occupy some underlying resources. In some extreme scenarios, the actual memory usage of a pod may not reach the memory in the pod flavor. To solve this issue, two annotations are provided to reserve the overhead for system components.
The resource.cci.io/memory-reservation annotation specifies whether to enable system overhead reservation. The default value is false, and the value true indicates that system overhead reservation is enabled. After this option is enabled, CCI 2.0 reserves 1 GiB of memory for the system components. If the memory exceeds that in the current pod flavor, the pod flavor is automatically upgraded a flavor that is lightly larger than the current flavor. You will be billed for the upgraded pod flavor.
The resource.cci.io/memory-burst-size annotation specifies whether to increase the container memory limits to the memory in the pod flavor. The default value is false, and the value true indicates that this option is enabled. After this option is enabled, the memory limits of all containers in the pod are adjusted to the memory in the pod flavor to increase the upper limit of the cgroup memory in the host environment. After system overhead reservation is enabled, the memory limited by cgroup can be released for application containers after the pod flavor is upgraded.
Table 1 Example
Pod Configuration
Resource Requests
Upgraded Pod Flavor
Final Pod Flavor on CCI
The pod has only one container, and only resource requests are configured. System overhead reservation and increasing memory limits to the memory in the pod flavor are enabled.
annotations:
  "resource.cci.io/memory-reservation": "true"
  "resource.cci.io/memory-burst-size": "true"
containers:
  - resources:
      requests:
        cpu: '1.5'
        memory: 2Gi
1.5 vCPUs and 3 GiB of memory
2 vCPUs and 4 GiB of memory
containers:
  - resources:
      limits:
        memory: 4Gi
      requests:
        cpu: '1.5'
        memory: 2Gi
How to calculate the required resources:
1. The pod flavor is upgraded based on the resource requests (1.5c2Gi).
2. System overhead reservation is enabled, and 1 GiB of memory (1.5c3Gi) is added.
3. The pod flavor is upgraded to 2c4Gi based on the rules described in Upgrading Pod Flavors.
4. The container memory limits are increased to the memory (4 GiB) in the pod flavor.
