Updated on 2026-09-09 GMT+08:00
Setting Mount Options for a Parallel File System Volume
This section describes how to configure mount options for a parallel file system volume. You can configure mount options for a PV and then bind the PV to a PVC.
When you mount a parallel file system volume, CCI 2.0 sets the parameters in Table 1 and Table 2 by default. The parameters in Table 1 cannot be canceled. You can configure other mount options if needed. For details, see Mounting a Parallel File System.
Table 1 Mandatory mount options configured by default
Mandatory
Type
use_ino
Yes
No parameter value is required.
Description: inode numbers allocated by obsfs. This option is enabled by default in read/write mode.
big_writes
Yes
Description: If this parameter is configured, the maximum size of the write cache can be changed.
nonempty
Yes
Description: The mount directory can contain files.
allow_other
Yes
Description: Other users can access the mount point.
no_check_certificate
Yes
Description: The server certificate is not verified.
Table 2 Optional mount options configured by default
Mandatory
Type
max_write
No
Integer
Description: This parameter is only valid when big_writes is configured. The recommended value is 128 KB.
Default value: 131072
ssl_verify_hostname
No
Integer
Description: Do not verify the SSL certificate using the host name.
Default value: 0
max_background
No
Integer
Description: the maximum number of requests that can be waited in the backend. The value is automatically used by the parallel file system volume.
Default value: 100
umask
No
Integer
Description: file permission umask. For example, if the umask value is 022, the directory permission (the maximum permission is 777) is 755 (777 – 022 = 755, rwxr-xr-x).
Default value: 0
Configuring Mount Options in a PV
You can use the mountOptions field to configure mount options in a PV. The options you can configure in mountOptions are listed in Mount Options for a Parallel File System Volume.
  1. Use ccictl to connect to CCI 2.0.
  2. Configure mount options in a PV. The following is an example:
    apiVersion: cci/v2
    kind: PersistentVolume
      name: pv-obs                                  # PV name
      accessModes:
      - ReadWriteMany                               # Access mode. The value must be ReadWriteMany for parallel file system volumes.
      capacity:
        storage: 1Gi                               # Storage capacity. This parameter is only for verification. Its value cannot be empty or 0, and any value you set does not take effect for parallel file systems.
      csi:
        driver: obs.csi.everest.io                  # Storage driver that the volume depends on
        fsType: obsfs                              # Instance type
        volumeHandle: <your_file_system_name>   # Name of the parallel file system
        nodePublishSecretRef:                       # Secret for the parallel file system volume
          name: <your_secret_name>                  # Secret name
          namespace: <your_namespace>               # Name of the secret
      persistentVolumeReclaimPolicy: Retain         # Reclaim policy
      storageClassName: csi-obs                  # Storage class name
      mountOptions:                                 # Mount options
      - umask=027
  3. Create a PVC, bind the created PV to it, and mount the PVC to the containers in the workload. For details, see Creating a Volume from an Existing Parallel File System.
  4. Check whether the mount options are effective.
    In this example, the PVC is mounted to the workload that uses the nginx:latest image. You can log in to the node where the pod with the mounted parallel file system volume is located and run the following command to view the process details:
    ps -ef | grep obsfs
    Information similar to the following is displayed:
    root      1470     1  0 Jul03 ?        00:01:23 /bin/obsfs {your_obs_name} /mnt/paas/kubernetes/kubelet/pods/{pod_uid}/volumes/kubernetes.io~csi/{your_pv_name}/mount -o url=https://{endpoint}:443 -o endpoint={region} -o passwd_file=/opt/everest-host-connector/obstmpcred/{pod_uid}/{your_obs_name} -o allow_other -o nonempty -o big_writes -o use_ino -o no_check_certificate -o ssl_verify_hostname=0 -o max_background=100 -o umask=027 -o max_write=131072
