Enabling Pod Metrics
CCI 2.0 supports basic monitoring of pod resources with multiple metrics, such as metrics for CPU, memory, disk, and network. Pods have built-in system agents, which provide pod and container metrics over HTTP by default. The agents are integrated into pods and occupy resources in the pods. You are advised to reserve 30-MB memory.
Basic metrics include those for CPU, memory, disk, and network. For details, see Resource Metrics.
Configuration Example
apiVersion: cci/v2
kind: Pod
annotations:
resource.cci.io/pod-size-specs: 2.00_4.0
resource.cci.io/instance-type: general-computing # Pod type
monitoring.cci.io/enable-pod-metrics: 'true'
monitoring.cci.io/metrics-port: '19100'
labels:
app: nginx
namespace: test
containers:
- name: centos
image: centos:latest
resources:
limits:
cpu: 2000m
memory: 4096Mi
requests:
cpu: 2000m
memory: 4096Mi
command:
- sh
- '-c'
- 'while true; do echo hello; sleep 10; done'
lifecycle: {}
dnsPolicy: ''
imagePullSecrets:
- name: imagepull-secret | Annotation | Mandatory | Type | Description |
| monitoring.cci.io/enable-pod-metrics | No | String | Whether to enable metric monitoring. The default value is true. The value false indicates that metric monitoring is disabled. |
| monitoring.cci.io/metrics-port | No | String | Listening port of pod exporter. The value ranges from 1 to 65535. The default value is 19100. |
Obtaining Resource Metrics
Once pod metric monitoring is enabled, run the following command on a network that can access the pod to obtain the pod monitoring data:
curl $podIP:$port/metrics
- $podIP: IP address of the pod
- $port: listening port
