Updated on 2025-10-31 GMT+08:00
Viewing Metrics on the CCI 2.0 Console
A Prometheus instance for cloud services can be used to monitor multiple metrics of CCI 2.0. You can view metrics on the CCI 2.0 console.
Only one Prometheus instance for cloud services can be created in an enterprise project.
CCI 2.0 supports monitoring only in the TR-Istanbul, AF-Johannesburg, AP-Singapore, and ME-Riyadh regions.
Step 1: Create a Prometheus Instance
  1. Log in to the AOM 2.0 console.
  2. In the navigation pane, choose Prometheus Monitoring > Instances. On the displayed page, click Add Prometheus Instance.
  3. Set the instance name, enterprise project, and instance type.
    If the CCE Cloud Bursting Engine for CCI add-on is being used or required, the CCE cluster also needs this Prometheus instance, with the instance type set to Prometheus for CCE.
  4. Click OK.
Step 2: Connect Metrics Using the CCI 2.0 Console
You can connect to monitoring metrics in either of the following ways: Method 1 is easy to use and suitable for quick access. Method 2 is flexible and suitable for large-scale or automatic scenarios.
  1. Log in to the CCI 2.0 console.
  2. In the navigation pane, choose Namespaces. Locate the target namespace, click Edit in the Operation column, and enable Connect to AOM (Optional).
  3. Select the AOM instance. For details about how to create an AOM instance, see Step 1: Create a Prometheus Instance.
  4. Click OK.
  1. Click the name of the created Prometheus instance.
  2. In the navigation pane, choose Settings. In the Credential area, click Add Access Code.
  3. Click OK.
  4. Obtain the values of <project_id>, <aom_id>, and <aom_secret>.
  5. Combine the obtained values into a character string in the format of <project_id>_<aom_id>: <aom_secret>.
    There must be a space after the colon (:).
  6. Encode the character string using Base64.
    You can run the following shell commands for encoding:
    project_id=<project_id>
    aom_id=<aom_id>
    aom_secret=<aom_secret>
    echo -n "${project_id}_${aom_id}: ${aom_secret}" |base64 -w 0
  7. Fill the Base64-encoded character string in the following template to replace {AOMAuthBase64}, and then copy the code.
    kind: Secret
    apiVersion: cci/v2
    data:
      aom_auth: {AOMAuthBase64}
    type: cci/secure-opaque
  8. Log in to the CCI 2.0 console.
  9. In the navigation pane, choose Configuration Center.
  10. Click the Secrets tab.
  11. Click Create from YAML and use the copied code to replace the code on the CCI 2.0 console to create an AOM app secret.
Step 3: View Metrics on the CCI 2.0 Console
You can view the metrics of Deployments and pods on the CCI 2.0 console.
Viewing Metrics of a Deployment
  1. In the navigation pane, choose Workloads. On the displayed page, click the Deployments tab.
  1. Locate the Deployment and click Monitor in the Operation column. You can also click the name of the target workload to go to the details page. On the displayed page, click the Monitoring tab to view the metrics. For more metrics, go to the AOM console to query all metrics or use PromQL statements to query related metrics.
    Table 1 Workload metrics
    Category
    Metric Name
    Definition
    CPU
    CPU Usage
    CPU used by all pods of a workload during different time periods/CPU limits of all pods of the workload × 100%
    Used CPU
    Number of vCPUs used by all pods of a workload
    Memory
    Memory Usage
    Total memory used by all pods of a workload during different time periods/Memory limits of all pods of the workload × 100%
    Used Memory
    Network
    Network Rate
    • Total number of bytes sent by the containers in all pods of a workload per second during different time periods
    • Total number of bytes received by the containers in all pods of a workload per second during different time periods
    Network Packet Loss Rate
    • Packet loss (sender): The number of packets lost by all pods of the workload during different time periods/Total number of packets sent by all pods of the workload × 100%
    • Packet loss (receiver): The number of packets lost by all pods of the workload during different time periods/Total number of packets received by all pods of the workload × 100%
    Pod
    Pod CPU Usage
    CPU used by a pod of the workload during different time periods/CPU limit of the pod × 100%
    Pod Memory Usage
    Memory that has been used by a pod of the workload during different time periods/Memory limit of the pod × 100%
Viewing Pod Metrics
  1. In the navigation pane, choose Workloads. On the displayed page, click the Deployments or Pods tab.
  1. Locate the target workload or pod and click Monitor in the Operation column. You can also click the name of the target pod to go to the details page. On the displayed page, click the Monitoring tab to view the metrics. For more metrics, go to the AOM console to query all metrics or use PromQL statements to query related metrics.
    Table 2 Pod metrics
    Category
    Metric Name
    Definition
    CPU
    CPU Usage
    CPU used by all containers in a pod during different time periods/CPU limits of all containers in the pod × 100%
    Used CPU
    Number of vCPUs used by all containers in a pod
    Memory
    Memory Usage
    Total memory used by all containers in a pod during different time periods/Memory limits of all containers in the pod × 100%
    Used Memory
    Network
    Network Rate
    • Total Outbound Rate: the total number of bytes transmitted by all containers in a pod per second
    • Total Inbound Rate: the total number of bytes received by all containers in a pod per second
    Container
    Container CPU Usage
    CPU used by a container in a pod during different time periods/CPU limit of the container × 100%
    Container Memory Usage
    Memory that has been used by a container in a pod during different time periods/Memory limit of the container × 100%
