Configuring the Log Level for the Network Sidecar
From version 1.5.53, you can edit the spec.custom.proxySidecarLogLevel field in the YAML file of the add-on to set the log level. Logs of the configured level will be output.
- Log in to the CCE console.
- Click the name of the target CCE cluster to go to the cluster Overview page.
- In the navigation pane, choose Add-ons.
- Select the CCE Cloud Bursting Engine for CCI add-on and click Edit.
- Click Edit YAML.
- Edit the spec.custom.proxySidecarLogLevel field in the YAML file of the add-on to set the log level. Logs of the configured level will be output.
The following is an example YAML file:
custom: .... proxySidecarLogLevel: 2 #Specifies the log level. ....Table 1 Parameter description Parameter
Mandatory
Type
No
Integer
Description: log level.
Value options:
- 0: Error and alarm logs are output.
- 2 (default): Error, alarm, and program run logs are output.
- Click OK. In the instance list of the add-on, if the instance status is Running, the add-on has been deployed and is functioning normally.
