Help Center/ Cloud Container Instance (CCI)/ User Guide/ Using CCI with CCE/ Using a Sidecar Container/ Replicating Environment Variables and Volume Mount Points of a Service Container
Updated on 2026-04-28 GMT+08:00
In scenarios such as container log collection and processing, configuration management, and data synchronization, you can transfer the configuration file path through environment variables or mount the volume of the main service container to the sidecar container through the shared volume mount point to implement specific functions. CCI allows you to replicate the environment variables (env) and volume mount points (volumeMounts) of a service container to implement specific functions. This simplifies the operations.
You can replicate environment variables and volume mount points of a service container in the following ways:
If you use a ClusterExtensionProfile or ExtensionProfile to replicate environment variables and volume mount points of a service container, you need to configure the sidecar container first. For details, see Configuring the Sidecar Container.
Functions
Table 1 Functions
Function
Replicate environment variables of the service container when the sidecar container is injected.
  • Replicate environment variables by container name and environment variable name.
Replicate the volume mount points of the service container when the sidecar container is injected.
  • Replicate volume mount points by container name and volumeMountName.
Table 2 Constraints
Field
Constraint
envFromContainer
  • name in envFromContainer cannot be empty.
  • name in envFromContainer cannot be duplicate or the same as any env name in the env configuration of the sidecar container.
  • Either name or index in containerFieldRef must be configured.
  • The value of fieldPath in containerFieldRef must be name or start with env..
volumeMountFromContainer
  • volumeMountName in volumeMountFromContainer cannot be empty.
  • volumeMountName in volumeMountFromContainer cannot be duplicate or the same as any name in the volumeMounts configuration of the sidecar container.
  • Either name or index in containerRef must be configured.
Method 1: Using Annotations
Add the envFromContainer and volumeMountFromContainer annotations to copy the environment variables and volume mount points of the service container.
bursting.cci.io/pod-sidecars: '{"containers":[{"name":"busybox","image":"busybox:latest","command":["sh","-c","sleep 3600"],"resources":{},"envFromContainer":[{"name":"POD_IP","containerFieldRef":{"index":0,"fieldPath":"env.POD_IP"}},{"name":"POD_NAME","containerFieldRef":{"name":"nginx","fieldPath":"env.POD_NAME"}},{"name":"CONTAINER_NAME","containerFieldRef":{"index":0,"fieldPath":"name"}}],"volumeMountFromContainer":[{"volumeMountName":"log-storage","containerRef":{"index":0}},{"volumeMountName":"log-storage1","containerRef":{"name":"nginx"}}]}]}'
Method 2: Using a ClusterExtensionProfile
  1. Generate a YAML file. Use a ClusterExtensionProfile to configure the environment variables and volume mount points of the sidecar container.
    The following is an example YAML file:
    apiVersion: bursting.cci.io/v1
    kind: ClusterExtensionProfile
      actions:
        podSidecars:
          containers:
          - command:
            - sh
            - -c
            - sleep 3600
            image: busybox:latest
            envFromContainer:
            - containerFieldRef:
                fieldPath: env.POD_IP
                index: 0
                fieldPath: env.POD_NAME
                fieldPath: name
                index: 0
            volumeMountFromContainer:
            - containerRef:
                index: 0
              volumeMountName: log-storage
            - containerRef:
              volumeMountName: log-storage1
      namespaceLabels:
        matchLabels:
            key: value
  2. Create the object.
    kubectl apply -f <podsidecar-cluster-profile>     #YAML file name (Replace it with the actual file name.)
  3. (Optional) Verify that the object has been created.
    kubectl get cextp
Method 3: Using an ExtensionProfile
  1. Generate a YAML file. Use an ExtensionProfile to configure the environment variables and volume mount points of the sidecar container.
    kind: ExtensionProfile
      actions:
        podSidecars:
          containers:
          - command:
            - sh
            - -c
            - sleep 3600
            envFromContainer:
                index: 0
                fieldPath: name
                index: 0
            - containerRef:
                index: 0
            - containerRef:
      objectLabels:
        matchLabels:
          key1: value1
    kubectl apply -f <podsidecar-profile>     #YAML file name (Replace it with the actual file name.)
    kubectl get extp
Parameter Description
Table 3 Key parameters
initContainers
The list of init containers injected on CCI through pod.spec.initContainers. The structure of an init container is similar to that of an init container in the pod, with parameters position, envFromContainer, and volumeMountFromContainer added. For details, see Table 4.
containers
The list of containers injected on CCI through pod.spec.containers. For details, see Table 4.
volumes
The list of volumes injected on CCI through pod.spec.volumes.
Table 4 Container parameters
Mandatory
Type
position
No
String
You can configure the position field for a container to specify where the injection is to be performed. If position is set to head, the container is injected at the beginning. If position is set to tail, the container is injected at the end. By default, the container is injected at the end. Containers with the same position settings are injected in the sequence specified by actions.podSidecars.
restartPolicy
No
String
Container restart policy. This parameter is valid only in initContainers. If this parameter is set to Always, the container runs as a native Kubernetes sidecar container. This function depends on the CCE Cloud Bursting Engine for CCI add-on v1.5.80 or later.
