Updated on 2025-10-31 GMT+08:00
Associating a Deployment with a PoolBinding
A PoolBinding can be associated with a Deployment. After a PoolBinding is created, the endpoints of the pods for the Deployment are automatically added to or removed from the associated backend server group.
  • You have created a backend server group on the ELB console.
  • You have created a Deployment on the CCI 2.0 console.
Method 1: Managing PoolBindings Using ccictl
  • poolbinding.yaml example
    apiVersion: loadbalancer.networking.openvessel.io/v1
    kind: PoolBinding
      name: test-c1       #Name of the PoolBinding to be created
      namespace: test-ns  #Namespace of the PoolBinding. It must be in the same namespace as the associated Deployment.
      poolRef:
        id: e08*****-****-****-****-********29c1 #ID of the created backend server group
      targetRef:
        kind: Deployment  #Type of the backend object. In this example, the backend object is a Deployment.
        group: cci/v2     #Group of the backend object
        name: test-name   #Name of the backend object, which is the name of the created Deployment in this example
        port: 80          #Target port number of the backend object. If the backend object is a Deployment, the port is the container port.
  • Common ccictl commands
    # Create a PoolBinding.
    ccictl create -f poolbinding.yaml
    # Query details about all PoolBindings in a namespace.
    ccictl get plb -n $namespace -oyaml
    # Query a PoolBinding in a namespace.
    ccictl get plb -n $namespace $name -oyaml
    # Delete a PoolBinding.
    ccictl delete plb -n $namespace $name
Table 1 Key parameter descriptions
$namespace-name
$name
PoolBinding name
Method 2: Managing PoolBindings Using curl Commands
  • poolbinding.json example
        "apiVersion": "loadbalancer.networking.openvessel.io/v1",
        "kind": "PoolBinding",
        "metadata": {
            "name": "test-c1",       #Name of the PoolBinding to be created
            "namespace": "test-ns"   #Namespace of the PoolBinding. It must be in the same namespace as the associated Deployment.
        "spec": {
            "poolRef": {
                "id": "e08*****-****-****-****-********29c1"  //ID of the created backend server group
            "targetRef": {
                "kind": "Deployment",    #Type of the backend object. In this example, the backend object is a Deployment.
                "group": "cci/v2",       #Group of the backend object
                "name": "test-name",     #Name of the backend object, which is the name of the created Deployment in this example
                "port": 80               #Target port number of the backend object. If the backend object is a Deployment, the port is the container port.
  • Common curl commands
    curl -k -H "Content-Type: application/json" -H "X-Auth-Token: $token" "https://$endpoint/apis/loadbalancer.networking.openvessel.io/v1/namespaces/$namespace-name/poolbindings" -X POST -d@poolbinding.json
    curl -k -H "Content-Type: application/json" -H "X-Auth-Token: $token" "https://$endpoint/apis/loadbalancer.networking.openvessel.io/v1/namespaces/$namespace-name/poolbindings/$name"
    curl -k -H "Content-Type: application/json" -H "X-Auth-Token: $token" "https://$endpoint/apis/loadbalancer.networking.openvessel.io/v1/namespaces/$namespace-name/poolbindings/$name" -X DELETE
Table 2 Key parameters in the commands
$token
Token used to authenticate requests.
$endpoint
CCI 2.0 endpoint.
An endpoint is the request address for calling an API. Endpoints vary with services and regions. An endpoint can be obtained from Regions and Endpoints.
$namespace-name
$name
PoolBinding name
