Help Center/ Cloud Container Instance (CCI)/ User Guide/ Using CCI Through the Console/ Images/ Pulling an Image from a Self-Managed Image Repository
Updated on 2026-09-09 GMT+08:00
An image in a self-managed image repository may fail to be pulled due to different protocols or certificate authentication failures. In this section, HTTP and a self-issued certificate are used as examples to describe how to create a Deployment or pod by pulling an image from a self-managed image repository.
Configuration Description
Table 1 Configuration description
Annotation
Example Value
cci.io/http-registries
"harbor.***.com,192.168.XX.XX:5000,100.95.XX.XX,http://harbor.***.com"
If an image that uses HTTP is pulled from a self-managed image repository, you need to configure this annotation. The value can contain the http:// prefix, port number, and relative path. Use commas (,) to separate multiple addresses, which can be private IP addresses, domain names, or public IP addresses. A maximum of 10 addresses are allowed.
cci.io/insecure-registries
"harbor.***.com,192.168.XX.XX:5000,100.95.XX.XX,https://harbor.***.com"
If an image that uses a self-issued certificate is pulled from a self-managed image repository, you need to add this annotation to skip certificate authentication. The value can contain the https:// prefix, port number, and relative path. Use commas (,) to separate multiple addresses, which can be private IP addresses, domain names, or public IP addresses. A maximum of 10 addresses are allowed.
  • If the image repository address contains a port number, the port number must be included in the configuration.
    For example, if the image path is 192.168.XX.XX:5000/nginx:latest, cci.io/http-registries can be set to 192.168.XX.XX:5000.
  • If HTTP is used, data transmission is not encrypted, and data is vulnerable to man-in-the-middle attacks and lacks identity authentication, which may cause data leak and service loss. You are advised to use HTTPS for image pull.
Example 1: An Image That Uses HTTP Is Pulled from a Self-Managed Image Repository
  • Creating a Deployment with 2 vCPUs and 4-GiB memory
    apiVersion: cci/v2
    kind: Deployment
      labels:
        app: http
      replicas: 1
      selector:
        matchLabels:
          app: http
      template:
          labels:
            app: http
          annotations:
            resource.cci.io/pod-size-specs: 2.00_4.0
            cci.io/http-registries: 192.168.XX.XX
          containers:
            - image: 192.168.XX.XX/harbor/nginx:latest
          imagePullSecrets:
            - name: harbor-secret-new
  • Creating a pod with 2 vCPUs and 4-GiB memory
    apiVersion: cci/v2
    kind: Pod
      annotations:
      containers:
        - image: '192.168.XX.XX/harbor/nginx:latest'
          imagePullPolicy: IfNotPresent
      imagePullSecrets:
Example 2: An Image That Uses a Self-Issued Certificate Is Pulled from a Self-Managed Image Repository
    apiVersion: cci/v2
    kind: Deployment
      labels:
        app: insecure
      replicas: 1
      selector:
        matchLabels:
          app: insecure
      template:
          labels:
            app: insecure
          annotations:
            cci.io/insecure-registries: 192.168.XX.XX
          containers:
          imagePullSecrets:
    apiVersion: cci/v2
    kind: Pod
      annotations:
      containers:
      imagePullSecrets:
