Using an Image Snapshot
You can use an image snapshot to create a pod in either of the following ways:
- Automatic matching
    The optimal image is selected from all available image snapshots based on the following: - Image matching degree: The images in the image snapshots are matched with those for the pod, and the mostly matched image snapshot is preferred.
- Time when image snapshots were created: Image snapshots that were created later are preferred.
   If you create a pod using both the specified and automatically matched image snapshots, and the two image snapshots conflict, 400 will be returned.
Automatic Matching
When creating a pod, you can add the following annotations to enable automatic image snapshot matching.
| Key | Example Value | Description |
| cci.io/image-snapshot-auto-match | "true" | Whether to enable automatic image snapshot matching. |
| cci.io/image-snapshot-usage-strategy | "size" | Automatic matching policy for image snapshots. The default value is size.
In the following example, a Deployment will be created.
apiVersion: cci/v2
kind: Deployment
  namespace: ns-test
  replicas: 1
  selector:
    matchLabels:
      app: redis
  template:
      labels:
        app: redis
      annotations:
        cci.io/image-snapshot-auto-match: "true"
      containers:
        - image: redis
          resources:
            limits:
              cpu: 500m
              memory: 1024Mi
            requests:
              cpu: 500m
              memory: 1024Mi
      imagePullSecrets:
        - name: imagepull-secret
  Specifying an Image Snapshot
When creating a pod, you can add the following annotations to specify the image snapshot and interception policy.
| cci.io/image-snapshot-specified-name | "my-imagesnapshot" | Name of the specified image snapshot. |
| cci.io/image-snapshot-reject-if-not-available | "true" | If the specified image snapshot does not exist or is unavailable, the image is pulled from the image repository by default. To intercept pod creation, set the value to "true". |
apiVersion: cci/v2
kind: Deployment
  namespace: ns-test
  replicas: 1
  selector:
    matchLabels:
      app: redis
  template:
      labels:
        app: redis
      annotations:
        cci.io/image-snapshot-specified-name: "my-imagesnapshot"
        cci.io/image-snapshot-reject-if-not-available: "true"
      containers:
        - image: redis
          resources:
            limits:
              cpu: 500m
              memory: 1024Mi
            requests:
              cpu: 500m
              memory: 1024Mi
      imagePullSecrets:
