Binding an Existing EIP to a Pod
Specifying the EIP ID for a Pod
If you configure the yangtse.io/eip-id annotation when creating a pod, an existing EIP will be automatically bound to the pod.
In the following example, a pod named nginx is created, and an existing EIP is automatically bound to the pod. Table 1 describes the parameters.
kind: Pod
apiVersion: cci/v2
namespace: ns-test
annotations:
yangtse.io/eip-id: 65eb3679-7a8d-4b24-b681-0b661axxxxcb
containers:
- name: container1
image: nginx:stable-alpine-perl
resources:
limits:
cpu: '1'
memory: 2G
requests:
cpu: '1'
memory: 2G
terminationMessagePath: /dev/termination-log
terminationMessagePolicy: File
restartPolicy: Always
terminationGracePeriodSeconds: 30
dnsPolicy: Default
securityContext: {}
imagePullSecrets:
- name: imagepull-secret Verifying the EIP Readiness
The startup time of the pod may be earlier than the time when the EIP assignment result is returned. During pod startup, the EIP may fail to be bound.
You can use an init container to check whether the EIP is assigned. After the pod IP address is assigned, the container network controller binds an EIP to the pod and returns the assignment result to the yangtse.io/allocated-ipv4-eip annotation of the pod. You can configure an init container in the pod and use the downwardAPI to mount the annotation to the init container through a volume to verify that the EIP has been assigned. You can configure the init container as follows:
kind: Pod
apiVersion: cci/v2
namespace: ns-test
annotations:
initContainers:
- name: init
image: busybox:latest
command: ['timeout', '60', 'sh', '-c', "until grep -E '[0-9]+' /etc/eipinfo/allocated-ipv4-eip; do echo waiting for allocated-ipv4-eip; sleep 2; done"]
volumeMounts:
- name: eipinfo
mountPath: /etc/eipinfo
volumes:
- name: eipinfo
downwardAPI:
items:
- path: "allocated-ipv4-eip"
fieldRef:
fieldPath: metadata.annotations['yangtse.io/allocated-ipv4-eip']
... Feedback
