Configuring Core Dumps
Before creating or updating a pod, you can use the system.cci.io/coredump annotation to set the core_pattern of the kernel, so that you can use generated core dump files to locate the cause of the pod failure.
How to Use
When creating a pod, you can add the core dump configuration (system.cci.io/coredump : '{"core_pattern": "/var/cores/core.%h.%e.%p.%t," max_size": 2048}') to the annotations field. If the maximum size is not specified, the default value is 1024. Core dumps will be used in the pod.
- The value of the system.cci.io/core_pattern field in the request must start with /var/, and the file path cannot contain vertical bars (|).
- The configured path must exist in the container. You are advised to mount volumes to store core dump files persistently.
Creating a Pod Using ccictl
You can add an annotation to the workload to control whether to enable core dumps for a pod, as shown in the following:
apiVersion: cci/v2
kind: Deployment
annotations:
description: ''
labels: {}
replicas: 2
selector:
matchLabels:
app: nginx
template:
annotations:
vm.cci.io/pod-size-specs: 2.00_4.0
resource.cci.io/pod-size-specs: 2.00_4.0
metrics.alpha.kubernetes.io/custom-endpoints: '[{api:'''',path:'''',port:'''',names:''''}]'
system.cci.io/coredump: "{\"core_pattern\": \"/var/cores/core.%h.%e.%p.%t\",\"max_size\": 1024}" # Enable core dumps.
log.stdoutcollection.kubernetes.io: '{"collectionContainers": ["container-0"]}'
labels:
app: nginx
containers:
- image: library/nginx:stable-alpine-perl
resources:
limits:
cpu: 2000m
memory: 4096Mi
requests:
cpu: 2000m
memory: 4096Mi
command: []
lifecycle: {}
dnsPolicy: ''
imagePullSecrets:
- name: imagepull-secret
dnsConfig: {}
minReadySeconds: 0
strategy:
type: RollingUpdate
rollingUpdate:
maxSurge: 0
maxUnavailable: 1
system.cci.io/coredump indicates that core dumps will be configured for the pod.
