Updated on 2026-09-09 GMT+08:00
Secrets
Secrets are objects that you can use to store sensitive data such as authentication information, certificates, and private keys. You can load a secret to a container as an environment variable when the container is started or mount a secret to a container as a file.
It is recommended that you encrypt the uploaded secrets.
Creating a Secret
  1. Log in to the CCI 2.0 console.
  2. In the navigation pane, choose Configuration Center.
  3. Select a namespace and click the Secrets tab.
  4. Click Create from YAML in the upper left corner and edit the YAML file. For details about the YAML file, see YAML format.
    CCI supports both JSON and YAML, and the file size cannot exceed 1 MiB.
  5. Click OK.
    You can view the newly created secret in the secret list.
Using a Secret
After a secret is created, you can mount it to a container for storage during pod creation. For example, mount a secret named aksk-secret to a container and set the storage volume name to volume2.
Figure 1 Mounting a secret
Secret File Format
  • Resource description in the secret.yaml file
    For example, you can use a secret to obtain the following key-value pairs and encrypt them for an application:
    key1: value1
    key2: value2
    The secret.yaml file is defined as below. Base64 encoding is required for the value of each key. For details about the Base64 encoding method, see Base64 Encoding.
    apiVersion: cci/v2
    kind: Secret
      name: mysecret           #Secret name
    data:
      key1: dmFsdWUx    #Base64 encoding required
      key2: dmFsdWUy  #Base64 encoding required
    type: Opaque         #The type must be Opaque.
  • Resource description in the secret.json file
    The following is the file content:
        "apiVersion": "cci/v2",
        "kind": "Secret",
        "metadata": {
            "name": "mysecret"
        "data": {
            "key1": "dmFsdWUx",
            "key2": "dmFsdWUy"
        "type": "Opaque"
Base64 Encoding
To perform Base64 encoding on a character string, run the echo -n {content-to-be-encoded} | base64 command.
root@ubuntu:~# echo -n "3306" | base64
MzMwNg==
