Event List
CCI 2.0 generates events when operations are performed on multiple resources, such as Deployments, ReplicaSets, Services, HPA policies, networks, and pods. Events for each resource are classified by the type field. Each resource corresponds to several fixed operation types and results. The additional information is only included in some complex scenarios.
Resource Object |
Operation Type |
Operation Result |
Additional Information |
Details |
Example Kubernetes-like Event Reason |
Deployment |
scale |
succeeded |
The Deployment is scaled. |
ScalingReplicaSet |
scale |
failed |
Deployment scaling failed. |
ReplicaSetCreateError |
delete |
processing |
Deleting the deployment... |
DeleteDeployment |
ReplicaSet |
scale |
succeeded |
The ReplicaSet is scaled. |
SuccessfulCreate and SuccessfulDelete |
scale |
failed |
ReplicaSet scaling failed. |
FailedCreate and FailedDelete |
Service |
publish |
failed |
Failed to publish the Service. |
SyncLoadBalancerFailed |
publish |
succeeded |
The Service is published. |
EnsuredLoadBalancer |
publish |
processing |
The Service is being published. |
EnsuringLoadBalancer |
delete |
failed |
Failed to delete the Service. |
DeleteLoadBalancerFailed |
delete |
succeeded |
The Service is deleted. |
DeletedLoadBalancer |
delete |
processing |
The Service is being deleted. |
DeletingLoadBalancer |
Horizontalpodautoscaler |
rescale |
failed |
Rescaling failed. |
FailedComputeMetricsReplicas and FailedRescale |
rescale |
failed |
computemetricsfailed |
Rescaling failed due to metrics calculation failure. |
FailedComputeMetricsReplicas |
rescale |
succeeded |
The Deployment is rescaled. |
SuccessfulRescale |
metricscrape |
failed |
Failed to obtain metrics. |
InvalidMetricSourceType and FailedGetResourceMetric |
metricscrape |
failed |
invalidmetricsourcetype |
Failed to obtain metrics due to invalid metric types. |
InvalidMetricSourceType |
scaleobjectparse |
failed |
invalidscaleobject |
Failed to parse the scaling object due to invalid objects. |
InvalidSelector and SelectorRequired |
scaleobjectparse |
failed |
ambiguoushpa |
Failed to parse the scaling object due to HPA matching disorder. |
AmbiguousSelector |
Network |
networkprepare |
failed |
subneterror |
Network preparation failed due to abnormal subnet synchronization. |
FailedSyncNetwork |
networkprepare |
processing |
The network is being prepared. |
ExternalDependenciesSyncd |
networkassign |
failed |
noavailableip |
Failed to allocate the network because no IP address is available. |
NetworkNoIPAvailable |
networkrelease |
failed |
Network release failed. |
NetworkFailed |
Pod |
networkassign |
failed |
Network allocation failed. |
FailedAssignENI and FailedAssignEIP |
networkrelease |
failed |
FailedReleaseENI |
networkprobe |
failed |
Network detection failed. |
warningNetworkNotReady |
schedule |
failed |
Scheduling failed. |
FailedScheduling |
schedule |
succeeded |
Scheduling succeeded. |
Scheduled |
logsetup |
failed |
Failed to configure logs. |
SetupLogFailed |
imagepull |
failed |
Failed to pull the image. |
ImagePullSecretNotFound, FailedPullImage, and BackOffPullImage |
imagepull |
failed |
imagepullsecretnotfound |
Failed to pull the image due to an imagepullsecret exception. |
ImagePullSecretNotFound |
imagepull |
processing |
Image is being pulled. |
Pulling |
imagepull |
succeeded |
Image is pulled. |
Pulled |
containerlifecyclehook |
failed |
poststartfailed |
PostStart failed. |
FailedPostStartHook |
failed |
prestopfailed |
PreStop failed. |
FailedPreStopHook |
containerlifecycleprobe |
failed |
Unhealthy or cgroup-level OOM |
Unhealthy, OOMKillContainer, and others |
succeeded |
Health check succeeded. |
Healthy |
podcreate |
failed |
Failed to create the pod. |
FailedCreate, FailedStart, and BackOffStart |
podcreate |
processing |
The pod is being created. |
SandboxChanged |
podcreate |
succeeded |
The pod is created. |
SuccessfulCreate and Started |
poddelete |
failed |
Failed to delete the pod. |
FailedKillPod and FailedDelete |
poddelete |
processing |
The pod is being deleted. |
Killing |
metricsetup |
succeeded |
The metric is set successfully. |
DefaultMetricsPort |
volumemount |
failed |
Failed to mount the volume. |
FailedAttachVolume and FailedMount |
volumemount |
succeeded |
The volume has been mounted. |
SuccessfulAttachVolume and SuccessfulMountVolume |
Pod |
ntpcheck |
succeeded |
The NTP status is synchronized normally. |
NTPSyncSuccess |
ntpcheck |
failed |
NTP status synchronization is abnormal.
At the early stage of pod startup, the NTP service may not be ready. Therefore, it is normal that the NTPSyncAbnormal event is triggered, which does not indicate that the NTP service is abnormal for a long time. If the NTPSyncAbnormal event persists and is not automatically restored to NTPSyncSuccess, you are advised to check the following:
NTPSyncAbnormal |
Flow control is performed on event reporting by event source. If the event reporting speed is too high, flow control is triggered and events may be lost. By default, up to 25 events can be reported for each event source. One event is reported every 5 minutes.
