Updated on 2025-10-31 GMT+08:00
Ephemeral Storage
By default, CCI 2.0 allocates 30 GiB of free ephemeral storage space to a pod. The storage space is unavailable when the pod is not in use. If the pod needs to write a large amount of data to rootfs or emptyDir or if the image size is greater than 30 GiB, you need to expand the ephemeral storage capacity.
  • The maximum ephemeral storage capacity is 994 GiB.
  • When the ephemeral storage space is expanded, workload creation is slower than before because the capacity expansion takes time.
Using YAML
  • When creating a pod, you need to add 10 GiB of ephemeral storage space. The YAML file is defined as follows:
    apiVersion: cci/v2
    kind: Pod
      namespace: ns
      extraEphemeralStorage:
        sizeInGiB: 10
      containers:
      - name: container-1
        image: nginx:latest
  • When creating a Deployment, you need to add 10 GiB of ephemeral storage space. The YAML file is defined as follows:
    apiVersion: cci/v2
    kind: Deployment
      namespace: ns
      replicas: 1
      selector:
        matchLabels:
          app: nginx
      template:
          labels:
            app: nginx
            sizeInGiB: 10
          containers:
          - image: nginx:latest
Verifying the Capacity Expansion
  1. Log in to the CCI 2.0 console.
  2. In the navigation pane, choose Workloads. Locate the target workload and click its name to go to the details page. On the Pods tab, locate the target pod and click View Terminal.
  3. Enter lsblk and press Enter to check the system disk size after the expansion. (The ephemeral storage capacity is 30 GiB by default.)
