CCE Cloud Bursting Engine for CCI Add-on
Overview
This section describes the functions, required resources, and custom annotations of the CCE Cloud Bursting Engine for CCI add-on (also called the bursting add-on).
Functions
The figure shows how workloads running in a CCE cluster with the bursting add-on installed are scheduled to CCI. In this process, you only need to take care of workload creation and scheduling.
Scheduling workloads to CCI is closely related to your workload settings.
| Pod Configuration Item | Description | Specification | Reference |
| Scheduling | You can manage pods in a CCE cluster in multiple ways to control their scheduling to CCI. You can also configure scheduling policies to improve cluster resource utilization. |
| Resource quotas | You can configure fields such as cpu and memory to specify resource specifications and limits for containers in a pod. The add-on upgrades appropriate resource specifications for higher resource utilization. | Appropriate pod resource quotas are selected. | |
| Images | You can configure service images and run your service containers in Huawei Cloud CCE clusters and CCI. |
| Storage | You can mount storage volumes to workloads for persistent data storage. |
| Networking | You can plan the network topology between CCE clusters and CCI. |
| Logging | You can install the Cloud Native Log Collection and bursting add-ons at the same time to collect pod logs in CCI. |
| Monitoring | You can install add-ons to connect to Monitoring Center for better O&M of pods scheduled to CCI. |
Resource Usage Description
The following table describes the cloud services involved when the bursting add-on is installed in a CCE cluster.
| Involved Cloud Service | Resource Description | Remarks |
| CCI | A namespace called cce-burst-{CCE cluster ID} will be created for the bursting add-on in CCI. |
| CCE | Workloads, secrets, ConfigMaps, PVs, and PVCs in CCE are synchronized to CCI and occupy CCE node resources. |
| ELB | If pods in the CCE cluster can communicate with the pods CCI through the Service, the bursting add-on automatically creates a shared load balancer. |
| VPC | Pods scheduled to CCI use the same VPC as the CCE cluster. | The CIDR block of the Service in the CCI namespace is 10.247.0.0/16. Do not configure the same CIDR block for the VPC subnet of the CCE cluster. |
| SWR | When you create a workload in CCE, the image can be pulled from SWR. | Ensure that your image has been pushed to SWR. |
Pod Annotations
If the bursting add-on is installed in a CCE cluster, custom annotations are required. The following table describes the annotations.
| Annotation Key | Description | Reference |
| scheduling.cci.io/managed-by-profile | Profile that manages the pods scheduled to CCI | |
| virtual-kubelet.cci.io/burst-pod-cpu | vCPUs of pods after they are scheduled to CCI | |
| virtual-kubelet.cci.io/burst-pod-memory | Memory of pods after they are scheduled to CCI | |
| coordinator.cci.io/inject-volumes | Annotation injected by the Cloud Native Logging add-on for collecting CCI pod logs | |
| logconf.k8s.io/fluent-bit-configmap-reference | Annotation injected by the Cloud Native Logging add-on for collecting CCI pod logs | |
| logconfigs.logging.openvessel.io | Annotation injected by the Cloud Native Logging add-on for collecting CCI pod logs | |
| sandbox-volume.openvessel.io/volume-names | Annotation injected by the Cloud Native Logging add-on for collecting CCI pod logs | |
| coordinator.cci.io/image-replacement | Annotation for replacing image path prefixes |
