Overview
There are multiple storage volume types that can be used by the pods scheduled to CCI. In this section, you can learn about:
- Storage volume types used by the pods scheduled to CCI.
- Typical scenarios of hostPath volumes and how to use them.
CCE pods that are scheduled to CCI supports ConfigMap, Secret, emptyDir, DownwardAPI, Projected, and PersistentVolumeClaims volumes, and the DownwardAPI and Projected volumes can only be used in bursting 1.3.25 and later versions.
- emptyDir: Subpaths are not supported.
- PersistentVolumeClaims: Only SFS and SFS Turbo cloud storage types and CSI storage classes are supported. Not volumes of all cloud storage types are supported by Volcano.
- Projected: If a source of the serviceAccountToken type is configured, the token in the corresponding service-account-token secret is mounted after the pod is scheduled to CCI. The token is valid for a long time and has no expected audience. That is, the expirationSeconds and audience configurations do not take effect.
Storage Volume Types
There are various storage volume types on the CCE cluster console.
The following table lists the storage volume types.
Volume Type |
Supported by CCI |
Remarks |
hostPath |
No |
ConfigMap |
Yes |
Secret |
Yes |
emptyDir |
Yes |
Subpaths are not supported when an emptyDir volume is mounted. For emptyDir, the value of sizeLimit must be an integer multiple of 1Gi and cannot be greater than 10 times the number of pod vCPUs. |
DownwardAPI |
Yes |
Projected |
Yes |
If a source of the serviceAccountToken type is configured, the token in the corresponding service-account-token secret is injected into the pod scheduled to CCI. The token is valid for a long time and has no audience. This means the settings of expirationSeconds and audience do not take effect. |
PersistentVolumeClaims |
Yes |
Only SFS and SFS Turbo are supported, with StorageClass set to CSI. |
How to Use hostPath
A hostPath volume can be used for storage when CCE or other Kubernetes clusters are used. However, CCI underlying clusters are used by all users so using hostPath volumes presents many security risks. As a result, hostPath volumes are unavailable. When a pod with a hostPath volume mounted is scheduled to CCI, the pods will be rejected. If hostPath configured in spec.volumes for a pod cannot be changed, you can configure annotations to allow the pod to be scheduled to CCI. During the bursting verification, hostPath needs to be removed or replaced with localDir, emptyDir, or flexVolume.
- The value of sizeLimit can only be 1Gi or 2Gi for LocalDir.
- For emptyDir, the value of sizeLimit must be an integer multiple of 1Gi and cannot be greater than 10 times the number of pod vCPUs.
- Replace hostPath with localDir.
"coordinator.cci.io/hostpath-replacement": '[{"name":"source-hostpath-volume","policyType":"replaceByLocalDir","localDir":{"sizeLimit":"1Gi"}}]
- Replace hostPath with flexVolume.
"coordinator.cci.io/hostpath-replacement": '[{"name":"source-hostpath-volume-1","policyType":"remove"},{"name":"source-hostpath-volume-2","policyType":"replaceByLocalDir","localDir":{"sizeLimit":"1Gi"}},{"name":"source-hostpath-volume-3","policyType":"replaceByEmptyDir","emptyDir":{"sizeLimit":"10Gi"}}]'
EVS supports three specifications: common I/O, high I/O, and ultra-high I/O. Set volumeType based on service requirements.
Table 1 EVS specifications EVS Specification
Disk Type
Application Scenario
Scenario Example
Common I/O
sata
SATA is used for backend storage. If an application processes only a few transactions but requires a large capacity and moderate read/write speed, you can store data on common I/O EVS disks.
Development testing and enterprise office applications
High I/O
sas
SAS is used for backend storage. If an application requires high performance, high read/write speed, and real-time data storage, you can store data on high I/O EVS disks.
File system creation and distributed file sharing
Ultra-high I/O
ssd
SSD is used for backend storage. If an application processes large volumes of data and requires high performance and high read/write speed, you can store data on ultra-high I/O EVS disks.
NoSQL, relational databases, and data warehouses (such as Oracle RAC and SAP HANA)
- Ignore all hostPath volumes.
"coordinator.cci.io/hostpath-replacement": '[{"name":"*","policyType":"remove"}]'
- Replace each hostPath volume with a different storage type.
For hostPath volumes whose path is /etc/localtime, if the name of a hostPath volume is the same as that of a replacement policy, the hostPath volume will be replaced. If the replacement policy name is *, hostPath volumes whose path is /etc/localtime will not be replaced.
Example (a Deployment):
apiVersion: apps/v1 kind: Deployment metadata: annotations: description: '' labels: virtual-kubelet.io/burst-to-cci: enforce appgroup: '' version: v1 name: test namespace: default spec: replicas: 2 selector: matchLabels: app: test version: v1 template: metadata: labels: app: test version: v1 annotations: coordinator.cci.io/hostpath-replacement: '[{"name": "test-log2", "policyType": "remove"}, {"name": "test-log", "policyType": "replaceByEmptyDir", "emptyDir":{"sizeLimit":"10Gi"}}, {"name": "test-log1", "policyType": "replaceByLocalDir", "localDir":{"sizeLimit":"1Gi"}}]' spec: containers: - name: container-1 image: nginx imagePullPolicy: IfNotPresent env: - name: PAAS_APP_NAME value: test - name: PAAS_NAMESPACE value: default - name: PAAS_PROJECT_ID value: 0b52a6e40b00d3682f36c0005163a82c resources: requests: cpu: 250m memory: 512Mi limits: cpu: 250m memory: 512Mi volumeMounts: - name: test-log mountPath: /tmp/log - name: test-log1 mountPath: /tmp/log1 - name: test-log2 mountPath: /tmp/log2 volumes: - hostPath: path: /var/paas/sys/log/virtual-kubelet type: "" name: test-log - hostPath: path: /var/paas/sys/log type: "" name: test-log1 - hostPath: path: /var/paas/sys/log2 type: "" name: test-log2
