- What's New
- Function Overview
- Billing
- Getting Started
- User Guide
- Best Practices
Developer Guide
- Overview
- Using Native kubectl (Recommended)
- Namespace and Network
- Pod
- Label
- Deployment
- EIPPool
- EIP
- Pod Resource Monitoring Metric
- Collecting Pod Logs
- Managing Network Access Through Service and Ingress
- Using PersistentVolumeClaim to Apply for Persistent Storage
- ConfigMap and Secret
- Creating a Workload Using Job and Cron Job
- YAML Syntax
API Reference
- Before You Start
- Calling APIs
- Getting Started
- Proprietary APIs
Kubernetes APIs
- ConfigMap
- Pod
- StorageClass
- Service
Deployment
- Querying All Deployments
- Deleting All Deployments in a Namespace
- Querying Deployments in a Namespace
- Creating a Deployment
- Deleting a Deployment
- Querying a Deployment
- Updating a Deployment
- Replacing a Deployment
- Querying the Scaling Operation of a Specified Deployment
- Updating the Scaling Operation of a Specified Deployment
- Replacing the Scaling Operation of a Specified Deployment
- Querying the Status of a Deployment
- Ingress
- OpenAPIv2
- VolcanoJob
- Namespace
- ClusterRole
- Secret
- Endpoint
- ResourceQuota
- CronJob
API groups
- Querying API Versions
- Querying All APIs of v1
- Querying an APIGroupList
- Querying APIGroup (/apis/apps)
- Querying APIs of apps/v1
- Querying an APIGroup (/apis/batch)
- Querying an APIGroup (/apis/batch.volcano.sh)
- Querying All APIs of batch.volcano.sh/v1alpha1
- Querying All APIs of batch/v1
- Querying All APIs of batch/v1beta1
- Querying an APIGroup (/apis/crd.yangtse.cni)
- Querying All APIs of crd.yangtse.cni/v1
- Querying an APIGroup (/apis/extensions)
- Querying All APIs of extensions/v1beta1
- Querying an APIGroup (/apis/metrics.k8s.io)
- Querying All APIs of metrics.k8s.io/v1beta1
- Querying an APIGroup (/apis/networking.cci.io)
- Querying All APIs of networking.cci.io/v1beta1
- Querying an APIGroup (/apis/rbac.authorization.k8s.io)
- Querying All APIs of rbac.authorization.k8s.io/v1
- Event
- PersistentVolumeClaim
- RoleBinding
- StatefulSet
- Job
- ReplicaSet
- Data Structure
- Appendix
- Out-of-Date APIs
- Change History
- Product Consulting
Basic Concept FAQs
- What Is CCI?
- What Are the Differences Between Cloud Container Instance and Cloud Container Engine?
- What Is an Environment Variable?
- What Is a Service?
- What Is Mcore?
- What Are the Relationships Between Images, Containers, and Workloads?
- What Are Kata Containers?
- Can kubectl Be Used to Manage Container Instances?
- What Are Core-Hours in CCI Resource Packages?
- Workload Abnormalities
Container Workload FAQs
- Why Service Performance Does Not Meet the Expectation?
- How Do I Set the Quantity of Instances (Pods)?
- How Do I Check My Resource Quotas?
- How Do I Set Probes for a Workload?
- How Do I Configure an Auto Scaling Policy?
- What Do I Do If the Workload Created from the sample Image Fails to Run?
- How Do I View Pods After I Call the API to Delete a Deployment?
- Why an Error Is Reported When a GPU-Related Operation Is Performed on the Container Entered by Using exec?
- Can I Start a Container in Privileged Mode When Running the systemctl Command in a Container in a CCI Cluster?
- Why Does the Intel oneAPI Toolkit Fail to Run VASP Tasks Occasionally?
- Why Are Pods Evicted?
- Why Is the Workload Web-Terminal Not Displayed on the Console?
- Why Are Fees Continuously Deducted After I Delete a Workload?
Image Repository FAQs
- Can I Export Public Images?
- How Do I Create a Container Image?
- How Do I Upload Images?
- Does CCI Provide Base Container Images for Download?
- Does CCI Administrator Have the Permission to Upload Image Packages?
- What Permissions Are Required for Uploading Image Packages for CCI?
- What Do I Do If Authentication Is Required During Image Push?
Network Management FAQs
- How Do I View the VPC CIDR Block?
- Does CCI Support Load Balancing?
- How Do I Configure the DNS Service on CCI?
- Does CCI Support InfiniBand (IB) Networks?
- How Do I Access a Container from a Public Network?
- How Do I Access a Public Network from a Container?
- What Do I Do If Access to a Workload from a Public Network Fails?
- What Do I Do If Error 504 Is Reported When I Access a Workload?
- What Do I Do If the Connection Timed Out?
- Storage Management FAQs
- Log Collection
- Account
- SDK Reference
- Videos
Show all
CCI Custom Policies
You can create custom policies to supplement the system-defined policies of CCI. For the actions that can be added to custom policies, see Permissions Policies and Supported Actions.
You can create custom policies in either of the following ways:
- Visual editor: Select a cloud service, specify actions and resources, and add request conditions. You do not need to have knowledge of JSON syntax.
- JSON: Create a policy in the JSON format from scratch or based on an existing policy.
The following provides some example custom policies of CCI.
Example Custom Policies
- Example 1: Updating a namespace
{ "Version": "1.1", "Statement": [ { "Effect": "Allow", "Action": [ "cci:namespace:update" ] } ] }
- Example 2: Denying namespace deletion
A policy with only "Deny" permissions must be used in conjunction with other policies for it to take effect. If you assign both "Allow" and "Deny" to a user, the "Deny" permissions take precedence over the "Allow" permissions.
The following method can be used if you need to assign permissions of the CCIFullAccess policy to a user but you want to prevent the user from deleting namespaces (cci:namespace:delete). Create a custom policy for denying namespace deletion, and attach both policies to the group to which the user belongs. Then, the user can perform all operations on CCI except deleting namespaces. The following is an example of a deny policy:
{ "Version": "1.1", "Statement": [ { "Action": [ "cci:namespace:delete" ], "Effect": "Deny" } ] }
- Example 3: Defining permissions for multiple services in a policy
A custom policy can contain the actions of multiple services that are of the global or project-level type. The following is an example policy containing actions of multiple services:
{ "Version": "1.1", "Statement": [ { "Action": [ "ecs:cloudServers:resize", "ecs:cloudServers:delete", "ecs:cloudServers:delete", "ims:images:list", "ims:serverImages:create" ], "Effect": "Allow" } ] }
