- What's New
- Function Overview
- Billing
- Getting Started
- User Guide
- Best Practices
Developer Guide
- Overview
- Using Native kubectl (Recommended)
- Namespace and Network
- Pod
- Label
- Deployment
- EIPPool
- EIP
- Pod Resource Monitoring Metric
- Collecting Pod Logs
- Managing Network Access Through Service and Ingress
- Using PersistentVolumeClaim to Apply for Persistent Storage
- ConfigMap and Secret
- Creating a Workload Using Job and Cron Job
- YAML Syntax
API Reference
- Before You Start
- Calling APIs
- Getting Started
- Proprietary APIs
Kubernetes APIs
- ConfigMap
- Pod
- StorageClass
- Service
Deployment
- Querying All Deployments
- Deleting All Deployments in a Namespace
- Querying Deployments in a Namespace
- Creating a Deployment
- Deleting a Deployment
- Querying a Deployment
- Updating a Deployment
- Replacing a Deployment
- Querying the Scaling Operation of a Specified Deployment
- Updating the Scaling Operation of a Specified Deployment
- Replacing the Scaling Operation of a Specified Deployment
- Querying the Status of a Deployment
- Ingress
- OpenAPIv2
- VolcanoJob
- Namespace
- ClusterRole
- Secret
- Endpoint
- ResourceQuota
- CronJob
API groups
- Querying API Versions
- Querying All APIs of v1
- Querying an APIGroupList
- Querying APIGroup (/apis/apps)
- Querying APIs of apps/v1
- Querying an APIGroup (/apis/batch)
- Querying an APIGroup (/apis/batch.volcano.sh)
- Querying All APIs of batch.volcano.sh/v1alpha1
- Querying All APIs of batch/v1
- Querying All APIs of batch/v1beta1
- Querying an APIGroup (/apis/crd.yangtse.cni)
- Querying All APIs of crd.yangtse.cni/v1
- Querying an APIGroup (/apis/extensions)
- Querying All APIs of extensions/v1beta1
- Querying an APIGroup (/apis/metrics.k8s.io)
- Querying All APIs of metrics.k8s.io/v1beta1
- Querying an APIGroup (/apis/networking.cci.io)
- Querying All APIs of networking.cci.io/v1beta1
- Querying an APIGroup (/apis/rbac.authorization.k8s.io)
- Querying All APIs of rbac.authorization.k8s.io/v1
- Event
- PersistentVolumeClaim
- RoleBinding
- StatefulSet
- Job
- ReplicaSet
- Data Structure
- Appendix
- Out-of-Date APIs
- Change History
- Product Consulting
Basic Concept FAQs
- What Is CCI?
- What Are the Differences Between Cloud Container Instance and Cloud Container Engine?
- What Is an Environment Variable?
- What Is a Service?
- What Is Mcore?
- What Are the Relationships Between Images, Containers, and Workloads?
- What Are Kata Containers?
- Can kubectl Be Used to Manage Container Instances?
- What Are Core-Hours in CCI Resource Packages?
- Workload Abnormalities
Container Workload FAQs
- Why Service Performance Does Not Meet the Expectation?
- How Do I Set the Quantity of Instances (Pods)?
- How Do I Check My Resource Quotas?
- How Do I Set Probes for a Workload?
- How Do I Configure an Auto Scaling Policy?
- What Do I Do If the Workload Created from the sample Image Fails to Run?
- How Do I View Pods After I Call the API to Delete a Deployment?
- Why an Error Is Reported When a GPU-Related Operation Is Performed on the Container Entered by Using exec?
- Can I Start a Container in Privileged Mode When Running the systemctl Command in a Container in a CCI Cluster?
- Why Does the Intel oneAPI Toolkit Fail to Run VASP Tasks Occasionally?
- Why Are Pods Evicted?
- Why Is the Workload Web-Terminal Not Displayed on the Console?
- Why Are Fees Continuously Deducted After I Delete a Workload?
Image Repository FAQs
- Can I Export Public Images?
- How Do I Create a Container Image?
- How Do I Upload Images?
- Does CCI Provide Base Container Images for Download?
- Does CCI Administrator Have the Permission to Upload Image Packages?
- What Permissions Are Required for Uploading Image Packages for CCI?
- What Do I Do If Authentication Is Required During Image Push?
Network Management FAQs
- How Do I View the VPC CIDR Block?
- Does CCI Support Load Balancing?
- How Do I Configure the DNS Service on CCI?
- Does CCI Support InfiniBand (IB) Networks?
- How Do I Access a Container from a Public Network?
- How Do I Access a Public Network from a Container?
- What Do I Do If Access to a Workload from a Public Network Fails?
- What Do I Do If Error 504 Is Reported When I Access a Workload?
- What Do I Do If the Connection Timed Out?
- Storage Management FAQs
- Log Collection
- Account
- SDK Reference
- Videos
Notice on Fixing Linux Kernel SACK Vulnerabilities
- Pods that are not associated with an ELB or EIP are not affected by these vulnerabilities because they are not exposed to the public network. Therefore, no action is required.
- Deployments that were created after 00:00 on July 11 are not affected by these vulnerabilities. However, you are advised to recreate pods in the Deployments that were created before 00:00 on July 11, during off-peak hours. For details, see Solution.
- After existing job or CronJobs are completed, pods created by the next job or CronJob will not be affected by these vulnerabilities. Therefore, no action is required.
- The CoreDNS add-on is not affected by these vulnerabilities. Therefore, no action is required.
Vulnerability Details
On June 18, 2019, Red Hat released a security notice, stating that the TCP SACK module of the Linux kernel is exposed to three security vulnerabilities (CVE-2019-11477, CVE-2019-11478, and CVE-2019-11479). These vulnerabilities are related to the maximum segment size (MSS) and TCP Selective Acknowledgment (SACK) packets. Remote attackers can exploit these vulnerabilities to trigger a denial of service (DoS), resulting in server unavailability or breakdown.
Reference links:
https://www.suse.com/support/kb/doc/?id=7023928
https://access.redhat.com/security/vulnerabilities/tcpsack
https://www.debian.org/lts/security/2019/dla-1823
https://wiki.ubuntu.com/SecurityTeam/KnowledgeBase/SACKPanic?
https://lists.centos.org/pipermail/centos-announce/2019-June/023332.html
https://github.com/Netflix/security-bulletins/blob/master/advisories/third-party/2019-001.md
Vulnerability Type |
CVE-ID |
Published |
Fixed |
Input validation flaw |
2019-06-17 |
2019-07-11 |
Resource management flaw |
2019-06-17 |
2019-07-11 |
2019-06-17 |
2019-07-11 |
Affected Products
Linux kernel version 2.6.29 and later
Solution
During off-peak hours, delete and recreate pods in the Deployments that were created before 00:00 on July 11.
- Log in to the CCI console. In the navigation pane on the left, choose Workloads > Deployments. On the page displayed, click a Deployment name.
- In the Pod List area on the Deployment details page, click Delete in the row where the pod resides. In the dialog box that is displayed, click Yes.
Figure 1 Deleting a podAfter the pod is deleted, the Deployment automatically creates new pods, as shown in Figure 2.
NOTICE:
If there are multiple pods in a Deployment, delete them individually. That is, delete a pod only after the previous pod is successfully re-created. Otherwise, services will be affected.
Appendix: Introduction to TCP SACKs
TCP is a connection oriented protocol. When two parties wish to communicate over a TCP connection, they establish a connection by exchanging certain information such as requesting to initiate (SYN) a connection, initial sequence number, acknowledgment number, maximum segment size (MSS) to use over this connection, and permission to send and process Selective Acknowledgements (SACKs). This connection establishment process is known as 3-way handshake.
TCP sends and receives user data by a unit called segment. A TCP segment consists of TCP Header, Options and user data. Each TCP segment has a Sequence Number (SEQ) and Acknowledgment Number (ACK).
These SEQ & ACK numbers are used to track which segments are successfully received by the receiver. ACK number indicates the next expected segment by the receiver.
Example:
User A sends 1 kilobyte of data through 13 segments of 100 bytes each. There are 13 segments in total because each segment has a TCP header of 20 bytes. On the receiving end, user B receives segments 1, 2, 4, 6, and 8-13. Segments 3, 5, and 7 are lost, and are not received by user B.
By using ACK numbers, user B will indicate that it is expecting segment 3, which user A understands as none of the segments after 2 were received by user B. Then user A will retransmit all the segments from 3 onwards, even though segments 4, 6, and 8–13 were successfully received by user B. User B has no way to indicate this to user A. This leads to an inefficient usage of the network.
