- What's New
- Function Overview
- Billing
- Getting Started
- User Guide
- Best Practices
Developer Guide
- Overview
- Using Native kubectl (Recommended)
- Namespace and Network
- Pod
- Label
- Deployment
- EIPPool
- EIP
- Pod Resource Monitoring Metric
- Collecting Pod Logs
- Managing Network Access Through Service and Ingress
- Using PersistentVolumeClaim to Apply for Persistent Storage
- ConfigMap and Secret
- Creating a Workload Using Job and Cron Job
- YAML Syntax
API Reference
- Before You Start
- Calling APIs
- Getting Started
- Proprietary APIs
Kubernetes APIs
- ConfigMap
- Pod
- StorageClass
- Service
Deployment
- Querying All Deployments
- Deleting All Deployments in a Namespace
- Querying Deployments in a Namespace
- Creating a Deployment
- Deleting a Deployment
- Querying a Deployment
- Updating a Deployment
- Replacing a Deployment
- Querying the Scaling Operation of a Specified Deployment
- Updating the Scaling Operation of a Specified Deployment
- Replacing the Scaling Operation of a Specified Deployment
- Querying the Status of a Deployment
- Ingress
- OpenAPIv2
- VolcanoJob
- Namespace
- ClusterRole
- Secret
- Endpoint
- ResourceQuota
- CronJob
API groups
- Querying API Versions
- Querying All APIs of v1
- Querying an APIGroupList
- Querying APIGroup (/apis/apps)
- Querying APIs of apps/v1
- Querying an APIGroup (/apis/batch)
- Querying an APIGroup (/apis/batch.volcano.sh)
- Querying All APIs of batch.volcano.sh/v1alpha1
- Querying All APIs of batch/v1
- Querying All APIs of batch/v1beta1
- Querying an APIGroup (/apis/crd.yangtse.cni)
- Querying All APIs of crd.yangtse.cni/v1
- Querying an APIGroup (/apis/extensions)
- Querying All APIs of extensions/v1beta1
- Querying an APIGroup (/apis/metrics.k8s.io)
- Querying All APIs of metrics.k8s.io/v1beta1
- Querying an APIGroup (/apis/networking.cci.io)
- Querying All APIs of networking.cci.io/v1beta1
- Querying an APIGroup (/apis/rbac.authorization.k8s.io)
- Querying All APIs of rbac.authorization.k8s.io/v1
- Event
- PersistentVolumeClaim
- RoleBinding
- StatefulSet
- Job
- ReplicaSet
- Data Structure
- Appendix
- Out-of-Date APIs
- Change History
- Product Consulting
Basic Concept FAQs
- What Is CCI?
- What Are the Differences Between Cloud Container Instance and Cloud Container Engine?
- What Is an Environment Variable?
- What Is a Service?
- What Is Mcore?
- What Are the Relationships Between Images, Containers, and Workloads?
- What Are Kata Containers?
- Can kubectl Be Used to Manage Container Instances?
- What Are Core-Hours in CCI Resource Packages?
- Workload Abnormalities
Container Workload FAQs
- Why Service Performance Does Not Meet the Expectation?
- How Do I Set the Quantity of Instances (Pods)?
- How Do I Check My Resource Quotas?
- How Do I Set Probes for a Workload?
- How Do I Configure an Auto Scaling Policy?
- What Do I Do If the Workload Created from the sample Image Fails to Run?
- How Do I View Pods After I Call the API to Delete a Deployment?
- Why an Error Is Reported When a GPU-Related Operation Is Performed on the Container Entered by Using exec?
- Can I Start a Container in Privileged Mode When Running the systemctl Command in a Container in a CCI Cluster?
- Why Does the Intel oneAPI Toolkit Fail to Run VASP Tasks Occasionally?
- Why Are Pods Evicted?
- Why Is the Workload Web-Terminal Not Displayed on the Console?
- Why Are Fees Continuously Deducted After I Delete a Workload?
Image Repository FAQs
- Can I Export Public Images?
- How Do I Create a Container Image?
- How Do I Upload Images?
- Does CCI Provide Base Container Images for Download?
- Does CCI Administrator Have the Permission to Upload Image Packages?
- What Permissions Are Required for Uploading Image Packages for CCI?
- What Do I Do If Authentication Is Required During Image Push?
Network Management FAQs
- How Do I View the VPC CIDR Block?
- Does CCI Support Load Balancing?
- How Do I Configure the DNS Service on CCI?
- Does CCI Support InfiniBand (IB) Networks?
- How Do I Access a Container from a Public Network?
- How Do I Access a Public Network from a Container?
- What Do I Do If Access to a Workload from a Public Network Fails?
- What Do I Do If Error 504 Is Reported When I Access a Workload?
- What Do I Do If the Connection Timed Out?
- Storage Management FAQs
- Log Collection
- Account
- SDK Reference
- Videos
Secrets
Secrets are Kubernetes objects that you can use to store sensitive data such as passwords, tokens, certificates, and private keys. You can load a secret to a container as an environment variable or a file when the container is started.
- Secrets and SSL certificates share the same quota.
- You are advised to encrypt the uploaded secret.
Creating Secrets
- Log in to the CCI console. In the navigation pane on the left, choose Configuration Center > Secrets. On the page displayed, select a namespace and click Create Secret.
- Select a creation mode. CCI allows you to create a secret by manually specifying parameters or uploading a file.
- Method 1: manually specifying parameters. Configure parameters based on the description in Table 1. Parameters marked with an asterisk (*) are mandatory.
Table 1 Parameter description Parameter
Basic information
* Name
Name of the secret.
Enter 1 to 253 characters starting and ending with a letter or digit. Only lowercase letters, digits, hyphens (-), and periods (.) are allowed. Do not enter two consecutive periods or a period adjacent to a hyphen.
Description of the secret.
* Data
Secret data that you want to use in the container. Key indicates the file name and Value indicates the file content.
- Click Add Data.
- Enter a key and a value. If you select Auto transcoding, the value you entered will be automatically encoded using Base64.
Label
Labels that you want to attach to various objects (such as applications, nodes, and services) in the form of key-value pairs.
Labels define the identifiable properties of these objects and are used to manage and select them.
- Click Add Label.
- Method 2: uploading a file.
Ensure that the file is in JSON or YAML format and the file size is less than 2 MB. For details, see Secret File Format.
Click Add File, select an existing secret resource file, and click Open.
- Click Create.
The newly created secret is displayed in the secret list.
Using Secrets
After you create a secret, you can reference it as an environment variable or mount it to a container path during workload creation.
The mount path cannot exceed 256 characters.
Secret File Format
- secret.yaml resource description file
For example, to obtain the following key-value pairs and encrypt them for an application, you can use the secret.
key1: value1
key2: value2
The content in the secret file secret.yaml is as follows. Base64 encoding is required for the value. For details about the Base64 encoding method, see Base64 Encoding.
apiVersion: v1 kind: Secret metadata: name: mysecret #Secret name annotations: description: "test" labels: label-01: value-01 label-02: value-02 data: key1: dmFsdWUx #Base64 encoding required key2: dmFsdWUy #Base64 encoding required type: Opaque #Must be Opaque
- secret.json resource description file
The content in the secret file secret.json is as follows:
{ "apiVersion": "v1", "kind": "Secret", "metadata": { "annotations": { "description": "test" }, "labels": { "label-01": "value-01", "label-02": "value-02" }, "name": "mysecret" }, "data": { "key1": "dmFsdWUx", "key2": "dmFsdWUy" }, "type": "Opaque" }
Base64 Encoding
To perform Base64 encoding on a character string, run the echo -n Content to be encoded | base64 command. The following is an example:
root@ubuntu:~# echo -n "3306" | base64 MzMwNg==
Creating a Secret Using kubectl
For details, see Secret.
