- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Show all
Add-ons
Check Items
Check the following items:
- Check whether the add-on status is normal.
- Check whether the add-on support the target version.
Solution
- Scenario 1: The add-on malfunctions.
Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane on the left, choose Add-ons and then obtain add-ons. Then, handle malfunctional add-ons.
- Scenario 2: The target cluster version does not support the current add-on version.
The add-on cannot be automatically upgraded with the cluster due to compatibility issues. In this case, log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane on the left, choose Add-ons and then manually upgrade the add-on.
- Scenario 3: After the add-on is upgraded to the latest version, it is still not supported by the target cluster version.
Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane on the left, choose Add-ons and then manually uninstall the add-on. For details about the supported add-on versions and substitutions, see Add-ons.
- Scenario 4: The add-on configuration does not meet the upgrade requirements. Upgrade the add-on and try again.
The following error information is displayed during the pre-upgrade check:
please upgrade addon [ ] in the page of addon managecheck and try again
