- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Basic Cluster Information
Kubernetes is an open-source container orchestration engine for automating deployment, scaling, and management of containerized applications.
For developers, Kubernetes is a cluster operating system. Kubernetes provides service discovery, scaling, load balancing, self-healing, and even leader election, freeing developers from infrastructure-related configurations.
Cluster Network
A cluster network can be divided into two parts:
- Container network: assigns IP addresses to containers in each pod of a cluster for communication. Currently, only Cloud Native 2.0 network model is supported.
- Service network: A Service is a Kubernetes object used to access containers. Each Service has a static IP address.
When you create a cluster, select a proper CIDR block for each network. Ensure that the CIDR blocks do not conflict with each other and have sufficient available IP addresses.
Cluster Lifecycle
Status |
Description |
Creating |
A cluster is being created and is requesting for cloud resources. |
Running |
A cluster is running properly. |
Upgrading |
A cluster is being upgraded. |
Unavailable |
A cluster is unavailable. |
Deleting |
A cluster is being deleted. |
CCE Autopilot Cluster Version Release Notes
The Kubernetes community continuously introduces new features and fixes vulnerabilities. CCE Autopilot will periodically release supported Kubernetes versions and provides feature updates and maintenance based on the Kubernetes community versions. For details, see the following sections:
To enable interoperability from one Kubernetes installation to the next, you must upgrade your Kubernetes clusters before the maintenance period ends.
