Using an Existing OBS Bucket or Parallel File System Through a Static PV
This section describes how to use an existing OBS bucket or parallel file system to statically create PVs and PVCs for implement data persistence and sharing in workloads.
If you want to create a cluster using commands, kubectl has been used to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
- If the volumes are created from an OBS bucket or parallel file system, the owner group and permission of the mount point cannot be modified.
- Hard links are not supported when common buckets are mounted.
- Multiple PVs can use the same OBS bucket or parallel file system with the following restrictions:
- All PVCs or PVs that use the same bucket or parallel file system cannot be mounted to a pod. This will result in a pod startup failure because not all PVCs can be mounted to the pod due to the same volumeHandle values of these PVs.
- The persistentVolumeReclaimPolicy parameter in the PVs should be set to Retain. If any other value is used, when a PV is deleted, the associated bucket or parallel file system may be deleted. In this case, other PVs associated with the bucket or parallel file system malfunction.
- If the bucket or parallel file system is repeatedly used, you are required to maintain data consistency. Enable isolation and protection for ReadWriteMany at the application layer and prevent multiple clients from writing the same file to prevent data overwriting and loss.
Using the Console
- Statically create a PVC and PV.
- In the navigation pane on the left, choose Storage. Then click the PVCs tab. In the upper right corner, click Create PVC. In the displayed dialog box, configure the parameters.
PVC Type
In this example, select OBS.
OBS Endpoint
To access an OBS volume in a CCE Autopilot cluster, you need to create a VPC endpoint for OBS.
PVC Name
Enter the PVC name, which must be unique in the same namespace.
Creation Method
- If underlying storage is available, create a PV or use an existing PV to statically create a PVC.
- If no underlying storage is available, select Dynamically provision. For details, see Using an OBS Bucket or Parallel File System Through a Dynamic PV.
In this example, select Create new to create a PV and PVC at the same time on the console.
PVa
Select an existing PV in the cluster. Create a PV in advance. For details, see "Creating a storage volume" in Related Operations.
You do not need to specify this parameter in this example.
OBSb
Click Select OBS. In the displayed dialog box, select the OBS storage that meets your requirements and click OK.
PV Nameb
Enter the PV name, which must be unique in the same cluster.
Access Modeb
OBS volumes support only ReadWriteMany, indicating that a storage volume can be mounted to multiple pods in read/write mode. For details, see Volume Access Modes.
Reclaim Policyb
You can select Delete or Retain to specify the reclaim policy of the underlying storage when the PVC is deleted. For details, see PV Reclaim Policy.
If multiple PVs use the same OBS volume, use Retain to avoid cascading deletion of underlying volumes.
Access Key (AK/SK)b
Custom: Customize a secret if you want to assign different user permissions to different OBS storage devices. For details, see Using a Custom Access Key (AK/SK) to Mount an OBS Volume.
Only secrets with the secret.kubernetes.io/used-by = csi label can be selected. The secret type is cfe/secure-opaque. If no secret is available, click Create Secret to create one.- Name: Enter a secret name.
- Namespace: Select the namespace where the secret is located.
- Access Key (AK/SK): Upload a key file in .csv format. For details, see Obtaining an Access Key.
Mount Optionsb
Enter the mounting parameter key-value pairs. For details, see Configuring OBS Mount Options.
a: The parameter is available when Creation Method is set to Use existing.
b: The parameter is available when Creation Method is set to Create new.
- Click Create to create a PVC and a PV.
In the navigation pane on the left, choose Storage. View the created PVC and PV on the PVCs and PVs tabs, respectively.
- Create a workload.
- In the navigation pane on the left, choose Workloads. Then click the Deployments tab.
- In the upper right corner, click Create Workload. On the displayed page, click Data Storage in the Container Settings area and click Add Volume to select PVC.
Mount and use storage volumes, as shown in Table 1. For details about other parameters, see Creating a Workload.
Table 1 Mounting a storage volume Parameter
PVC
Select an existing OBS volume.
Mount Path
Enter a mount path, for example, /tmp.
This parameter indicates the container path that the volume will be mounted to. Do not mount the volume to a system directory such as / or /var/run. This may cause container errors. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. If there are such files, they will be replaced, which will lead to a container startup or workload creation failure.NOTICE:If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container, or high-risk files on the host may be damaged.
Subpath
Enter the subpath of the storage volume and mount a path in the storage volume to the container. In this way, different folders of the same storage volume can be used in a single pod. tmp, for example, indicates that data in the mount path of the container is stored in the tmp directory of the storage volume. If this parameter is left blank, the root path is used by default.
Permission
- Read-only: You can only read the data in the mounted volume.
- Read-write: You can modify the volume mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
In this example, the volume is mounted to the /data path of the container. The container data generated in this path is stored in the OBS bucket or parallel file system.
- Configure other parameters and click Create Workload.
After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence and Sharing.
Using kubectl
- Use kubectl to connect to the cluster.
- Create a PV.
- Create the pv-obs.yaml file.
apiVersion: v1 kind: PersistentVolume metadata: annotations: pv.kubernetes.io/provisioned-by: everest-csi-provisioner everest.io/reclaim-policy: retain-volume-only # (Optional) The underlying storage is retained when the PV is deleted. name: pv-obs # PV name. spec: accessModes: - ReadWriteMany # Access mode. The value must be ReadWriteMany for OBS. capacity: storage: 1Gi # OBS volume capacity. csi: driver: obs.csi.everest.io # Dependent storage driver for the mounting. fsType: obsfs # Instance type. volumeHandle: <your_volume_id> # Name of the OBS volume. volumeAttributes: storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner everest.io/obs-volume-type: STANDARD everest.io/region: <your_region> # Region where the OBS volume is located. nodePublishSecretRef: # Custom secret of the OBS volume. name: <your_secret_name> # Custom secret name. namespace: <your_namespace> # Namespace of the custom secret. persistentVolumeReclaimPolicy: Retain # Reclaim policy. storageClassName: csi-obs # Storage class name. mountOptions: [] # Mount options.
Table 2 Key parameters Parameter
Mandatory
No
Optional.
Currently, only retain-volume-only is supported.
If the reclaim policy is Delete and the value is retain-volume-only, the associated PV is deleted while the underlying storage volume is retained, when a PVC is deleted.
fsType
Yes
Instance type. The value can be obsfs or s3fs.
- obsfs: Parallel file system, which is mounted using obsfs.
- s3fs: Object bucket, which is mounted using s3fs.
volumeHandle
Yes
OBS volume name.
Yes
OBS storage class.
- If fsType is set to s3fs, STANDARD (standard bucket) and WARM (infrequent access bucket) are supported.
- This parameter is invalid when fsType is set to obsfs.
everest.io/region
Yes
Region where the OBS bucket is deployed.
For details, see Regions and Endpoints.
No
Access key (AK/SK) used for mounting the OBS volume. You can use the AK/SK to create a secret and mount it to the PV. For details, see Using a Custom Access Key (AK/SK) to Mount an OBS Volume.
An example is as follows:nodePublishSecretRef: name: secret-demo namespace: default
mountOptions
No
Mount options. For details, see Configuring OBS Mount Options.
Yes
The Delete and Retain reclaim policies are supported. For details, see PV Reclaim Policy. If multiple PVs use the same OBS volume, use Retain to avoid cascading deletion of underlying volumes.
Delete:
- If everest.io/reclaim-policy is not specified, both the PV and OBS bucket will be deleted when a PVC is deleted.
- If everest.io/reclaim-policy is set to retain-volume-only, when a PVC is deleted, the PV will be deleted but the OBS bucket or parallel file system will be retained.
Retain: When a PVC is deleted, both the PV and underlying storage are retained. You need to manually delete these resources. After the PVC is deleted, the PV is in the Released state and cannot be bound to a PVC again.
storage
Yes
Storage capacity, in Gi.
For OBS, this field is used only for verification (cannot be empty or 0). Its value is fixed at 1, and any value you set does not take effect for OBS.
storageClassName
Yes
The StorageClass for OBS volumes is csi-obs.
- Run the following command to create a PV:
kubectl apply -f pv-obs.yaml
- Create a PVC.
- Create the pvc-obs.yaml file.
apiVersion: v1 kind: PersistentVolumeClaim metadata: name: pvc-obs namespace: default annotations: volume.beta.kubernetes.io/storage-provisioner: everest-csi-provisioner everest.io/obs-volume-type: STANDARD csi.storage.k8s.io/fstype: obsfs csi.storage.k8s.io/node-publish-secret-name: <your_secret_name> # Custom secret name. csi.storage.k8s.io/node-publish-secret-namespace: <your_namespace> # Namespace of the custom secret. spec: accessModes: - ReadWriteMany # The value must be ReadWriteMany for OBS. resources: requests: storage: 1Gi storageClassName: csi-obs # Storage class name, which must be the same as that of the PV. volumeName: pv-obs # PV name.
Table 3 Key parameters Parameter
Mandatory
No
Name of the custom secret specified in the PV.
No
Namespace of the custom secret specified in the PV.
storage
Yes
Requested capacity in the PVC, in Gi.
storageClassName
Yes
Storage class name, which must be the same as the storage class of the PV in 2.a.
volumeName
Yes
PV name, which must be the same as the PV name in 2.a.
- Run the following command to create a PVC:
kubectl apply -f pvc-obs.yaml
- Create a file named web-demo.yaml. In this example, the OBS volume is mounted to the /data path.
apiVersion: apps/v1 kind: Deployment metadata: name: web-demo namespace: default spec: replicas: 2 selector: matchLabels: app: web-demo template: metadata: labels: app: web-demo spec: containers: - name: container-1 image: nginx:latest volumeMounts: - name: pvc-obs-volume # Volume name, which must be the same as the volume name in the volumes field. mountPath: /data # Location where the storage volume is mounted. imagePullSecrets: - name: default-secret volumes: - name: pvc-obs-volume # Volume name, which can be changed as needed. persistentVolumeClaim: claimName: pvc-obs # PVC name.
- Run the following command to create a workload that the OBS volume is mounted to:
kubectl apply -f web-demo.yaml
After the workload is created, you can try Verifying Data Persistence and Sharing.
- View the deployed application and files.
- Run the following command to view the created pod:
kubectl get pod | grep web-demo
Expected output:web-demo-846b489584-mjhm9 1/1 Running 0 46s web-demo-846b489584-wvv5s 1/1 Running 0 46s
- Run the following commands in sequence to view the files in the /data path of the pods:
kubectl exec web-demo-846b489584-mjhm9 -- ls /data kubectl exec web-demo-846b489584-wvv5s -- ls /data
If no result is returned for both pods, no file exists in the /data path.
- Run the following command to create a file named static in the /data path:
kubectl exec web-demo-846b489584-mjhm9 -- touch /data/static
- Run the following command to check the files in the /data path:
Expected output:
static
- Verify data persistence.
- Run the following command to delete the pod named web-demo-846b489584-mjhm9:
kubectl delete pod web-demo-846b489584-mjhm9
Expected output:
pod "web-demo-846b489584-mjhm9" deleted
After the deletion, the Deployment controller automatically creates a replica.
The expected output is as follows, in which web-demo-846b489584-d4d4j is the newly created pod:web-demo-846b489584-d4d4j 1/1 Running 0 110s web-demo-846b489584-wvv5s 1/1 Running 0 7m50s
- Run the following command to check whether the files in the /data path of the new pod have been modified:
kubectl exec web-demo-846b489584-d4d4j -- ls /data
Expected output:
static
The static file is retained, indicating that the data in the file system can be stored persistently.
- Verify data sharing.
Expected output:web-demo-846b489584-d4d4j 1/1 Running 0 7m web-demo-846b489584-wvv5s 1/1 Running 0 13m
- Run the following command to create a file named share in the /data path of either pod: In this example, select the pod named web-demo-846b489584-d4d4j.
kubectl exec web-demo-846b489584-d4d4j -- touch /data/share
Check the files in the /data path of the pod.kubectl exec web-demo-846b489584-d4d4j -- ls /data
Expected output:
share static
- Check whether the share file exists in the /data path of another pod (web-demo-846b489584-wvv5s) as well to verify data sharing.
Expected output:
share static
After you create a file in the /data path of a pod, if the file is also created in the /data path of the other pod, the two pods share the same volume.
Related Operations
Operation |
Description |
Procedure |
Creating a storage volume (PV) |
You can create a PV on the CCE console. |
Updating an access key |
You can update the access key of object storage on the CCE console. |
Viewing events |
You can view event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV. |
Viewing a YAML file |
You can view, copy, and download the YAML files of a PVC or PV. |
