Updated on 2025-04-21 GMT+08:00
Using kubectl to Create an Nginx Ingress
An Nginx workload is used as an example to describe how you can create an Nginx Ingress using kubectl.
  • The NGINX Ingress Controller add-on has been installed in a cluster. For details about how to install the add-on, see Installing the Add-on.
  • A workload is available in the cluster (because an Ingress enables network access for workloads). If no workload is available, deploy a workload by referring to Creating a Workload.
  • A ClusterIP Service has been configured for the workload. For details about how to configure the Service, see ClusterIP.
  1. Use kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    The following uses HTTP as an example to describe how to configure the YAML file:
    kind: Ingress
      rules:
        - host: ''
          http:
            paths:
              - path: /
                backend:
                  service:
                    name: <your_service_name>  # Replace it with the name of your target Service.
                    port:
                      number: <your_service_port>  # Replace it with the port number of your target Service.
                property:
      ingressClassName: nginx   # Nginx Ingress is used.
    Table 1 Key parameters
    Mandatory
    Type
    ingressClassName
    Yes
    String
    nginx: indicates that Nginx Ingress is used. This option cannot be used if the NGINX Ingress Controller add-on is not installed.
    This parameter is mandatory when an Ingress is created by calling the API.
    host
    No
    String
    Domain name for accessing the Service. By default, this parameter is left blank, and the domain name needs to be fully matched. Ensure that the domain name has been registered and licensed. Once the domain name is specified, it must be used for access.
    path
    Yes
    String
    User-defined route path. All external access requests must match host and path.
    • The access path matching rule of Nginx Ingress is based on the path prefix separated by the slash (/) and is case-sensitive. If the subpath separated by a slash (/) matches the prefix, the access is normal. However, if the prefix is only a part of the character string in the subpath, the access is not matched. For example, if the URL is set to /healthz, /healthz/v1 is matched, but /healthzv1 is not matched.
    • The access path added here must exist in the backend application. Otherwise, the forwarding fails.
      For example, the default access URL of the Nginx application is /usr/share/nginx/html. When adding /test to the ingress forwarding policy, ensure the access URL of your Nginx application contains /usr/share/nginx/html/test. Otherwise, error 404 will be returned.
    No
    String
    Route matching policy.
    Default: STARTS_WITH (prefix match)
    Options:
    • EQUAL_TO: exact match
    • STARTS_WITH: prefix match
    pathType
    Yes
    String
    Path type. The options are as follows:
    • ImplementationSpecific: The matching method depends on Ingress Controller. The matching method defined by ingress.beta.kubernetes.io/url-match-mode is used in CCE.
    • Exact: exact matching of the URL, which is case-sensitive.
    • Prefix: prefix matching, which is case-sensitive. With this method, the URL path is separated into multiple elements by slashes (/) and the elements are matched one by one. If each element in the URL matches the path, the subpaths of the URL can be routed normally.
      • During prefix matching, each element must be exactly matched. If the last element of the URL is the substring of the last element in the request path, no matching is performed. For example, /foo/bar matches /foo/bar/baz but does not match /foo/barbaz.
      • When elements are separated by slashes (/), if the URL or request path ends with a slash (/), the slash (/) at the end is ignored. For example, /foo/bar matches /foo/bar/.
    See examples of ingress path matching.
  3. Create an Ingress.
    If information similar to the following is displayed, the Ingress has been created.
    ingress/ingress-test created
    View the created Ingress.
    kubectl get ingress
    If information similar to the following is displayed, the Ingress has been created, and the workload is accessible.
    NAME             HOSTS     ADDRESS          PORTS   AGE
    ingress-test     *         121.**.**.**     80      10s
  4. Enter http://121.**.**.**:80 in the address box of the browser to access the workload.
    121.**.**.** indicates the IP address of the unified load balancer.
