Associating a Subnet and Security Group with a Namespace or Workload Using a Container Network Configuration
In a CCE Autopilot cluster, you can configure subnets and security groups for containers by namespace or workload using NetworkAttachmentDefinition, which is a CRD resource. To configure a particular container subnet and security group for a specified namespace or workload, create a container network configuration (NetworkAttachmentDefinition) and associate it with the target namespace or workload. In this way, service subnets can be planned or services can be securely isolated.
Dimension |
Resources That a Container Network Configuration Can Be Associated With |
Namespace |
Workload |
Subnet and security group configurations |
All workloads created in the namespace associated with a container network configuration will use the same subnet and security group configurations. |
The workloads using the same container network configuration will use the same subnet and security group configurations. |
Supported CCE Autopilot cluster version |
v1.27.8-r0, v1.28.6-r0, and later |
Constraint |
A namespace can only be associated with one container network configuration. |
Only custom container network configurations that are not associated with any namespace can be specified. |
- The priorities (in descending order) of container network configurations used by a pod are as follows: Container network configuration directly associated with the pod > Container network configuration associated with the pod namespace > Default container network configuration of the cluster (default-network)
- If default-network is available in a cluster, it will be applied on all pods when no custom container network configuration has been configured. The default container subnet in the network settings on the Overview page is the container subnet in default-network. default-network cannot be deleted.
- If there is only one container network configuration in a cluster, it is the default container network configuration. If there are multiple container network configurations in a cluster, the one with the yangtse.io/default-network:true annotation is the default container network configuration. If there is no default container network configuration in a cluster, the pod that is not associated with any container network configuration fails to start after being created because no network interface can be allocated for the pod.
- Before deleting a custom container network configuration, delete the pods (with the cni.yangtse.io/network-status annotation) created using the configuration in the target namespace. For details, see Deleting a Container Network Configuration.
- When a subnet is added to a container network configuration, the VPC API /v2.0/subnets is called twice. The first call checks if the subnet is available, while the second call retrieves subnet information for persistence by the control plane components. Do not add more than 20 subnets at a time. If there are more than 20 subnets, traffic control will be triggered for the VPC API.
Creating a Container Network Configuration for a Namespace
After a container network configuration is created and associated with a namespace, all workloads created in the namespace will use the same subnet and security group configurations.
- Click the cluster name to access the cluster console, choose Settings in the navigation pane, and then click the Network tab.
- In the Container Network area, click Add. In the window that slides out from the right, configure parameters such as the pod subnet and security group.
- Name: Enter a name that contains a maximum of 63 characters. Do not use default-network, default, mgnt0, or mgnt1. They are reserved for system use.
- Associated Resource Type: Select a resource type that will be associated with the custom container network configuration. For details, see Table 1. To create a container network configuration for a namespace, select Namespace.
- Namespace: Select the namespace to be associated. The namespaces associated with different container network configurations must be unique. If no namespace is available, click Create Namespace to create one.
- Pod Subnet: Select one or more subnets. A maximum of 100 subnets can be selected. If no subnet is available, create one first. After the subnet is created, click the refresh button.
- Associate Security Group: The default value is the security group associated with the container network interface. You can also create one. After the security group is created, click the refresh button. A maximum of five security groups can be selected.
Figure 2 Creating a container network configuration for a namespace - Click OK. You will be redirected to the custom container network configuration list, where you can view new container network configuration.
Figure 3 Container network configuration list
- Use kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
- Create a YAML file for creating a custom container network configuration and associating the configuration with a namespace. You can use any file name. In this example, the file name is networkattachment-test.yaml.
vim networkattachment-test.yaml
Example file content:
apiVersion: k8s.cni.cncf.io/v1 kind: NetworkAttachmentDefinition metadata: annotations: yangtse.io/project-id: 05e38** name: example namespace: kube-system spec: config: | { "type":"eni-neutron", "args":{ "securityGroups":"41891**", "subnets":[ { "subnetID":"27d95**" } ] }, "selector":{ "namespaceSelector":{ "matchLabels":{ "kubernetes.io/metadata.name":"default" } } } }
Table 2 Key parameters Parameter
Mandatory
Type
apiVersion
Yes
String
API version. The value is fixed at k8s.cni.cncf.io/v1.
kind
Yes
String
Type of the object to be created. The value is fixed at NetworkAttachmentDefinition.
Yes
String
Project ID in the current region. For details, see Obtaining a Project ID.
name
Yes
String
Configuration name, which can be customized. Enter up to 63 characters. Start and end with a lowercase letter or digit. Only lowercase letters, digits, hyphens (-), and periods (.) are allowed. Do not use default-network, default, mgnt0, or mgnt1. They are reserved for system use.
namespace
Yes
String
Namespace of the configuration. The value is fixed at kube-system.
config
Yes
Object
Configuration content, which is a string in JSON format.
For details about the data structure of the config field, see Table 3.
Table 3 Data structure of the config field Parameter
Mandatory
Type
type
Yes
String
Network type. The value is fixed at eni-neutron.
args
Yes
Object
Security group and subnet configurations.
For details about the data structure of the args field, see Table 4.
selector
No
Object
Namespace where the configuration will take effect.
For details about the data structure of the selector field, see Table 5.
Table 4 Data structure of the args field Parameter
Mandatory
Type
securityGroups
No
String
ID of the security group to be configured. A maximum of five security groups can be associated. If no security group is planned, ensure that the security group is the same as that in default-network.
How to obtain:
Log in to the VPC console. In the navigation pane, choose Access Control > Security Groups. Click the target security group name and copy the ID on the Summary tab.
subnets
Yes
Array of subnetID objects
Container subnet ID list. Enter 1 to 100 subnet IDs. The format is as follows:
[{"subnetID":"27d95**"},{"subnetID":"827bb**"},{"subnetID":"bdd6b**"}]
The container subnet must be in the same VPC as the cluster.
How to obtain:
Log in to the VPC console. In the navigation pane, choose Virtual Private Cloud > Subnets. Click the target subnet name and copy the Subnet ID on the Summary tab.
Table 5 Data structure of the selector field Parameter
Mandatory
Type
namespaceSelector
No
matchLabels object
A Kubernetes standard selector. Enter the namespace label in the following format:
The namespaces for different configurations must be unique.
- Create the container network configuration.
kubectl create -f networkattachment-test.yaml
If information similar to the following is displayed, the configuration has been created:
networkattachmentdefinition.k8s.cni.cncf.io/example created
Creating a Container Network Configuration for a Workload
After such a container network configuration is created, all workloads associated with it will use the same subnet and security group configurations.
- Log in to the CCE console.
- Associated Resource Type: Select a resource type that will be associated with the custom container network configuration. For details, see Table 1. To create a container network configuration for a workload, select Workload.
Figure 4 Creating a container network configuration for a workload - Click OK. You will be redirected to the custom container network configuration list, where you can view new container network configuration.
Figure 5 Container network configuration list
- When creating a workload, select a custom container network configuration.
- In the navigation pane, choose Workloads. Then click the Deployments tab.
- Click Create Workload in the upper right corner of the page. In the Advanced Settings area, choose Network Configuration and determine whether to enable a specified container network configuration.
- Select an existing container network configuration. If no configuration is available, click Add to create one.
Figure 6 Selecting a container network configuration
- Configure other parameters and click Create Workload.
Return to the Settings page. In the container network configuration list, the name of the resource associated with the created container network configuration is displayed.
Figure 7 Resources associated with a container network configuration
After a container network configuration is created, all workloads associated with it will use the same subnet and security group configurations.
- Connect to a cluster using kubectl.
- Create a YAML file for creating a custom container network configuration. You can use any file name. In this example, the file name is networkattachment-test.yaml.
apiVersion: k8s.cni.cncf.io/v1 kind: NetworkAttachmentDefinition metadata: annotations: yangtse.io/project-id: 80d5a** name: example namespace: kube-system spec: config: | { "type":"eni-neutron", "args":{ "securityGroups":"f4983**", "subnets":[ { "subnetID":"5594b**" } ] } }
Table 6 Key parameters Parameter
Mandatory
Type
apiVersion
Yes
String
kind
Yes
String
Yes
String
name
Yes
String
namespace
Yes
String
config
Yes
Object
For details about the data structure of the config field, see Table 7.
Table 7 Data structure of the config field Parameter
Mandatory
Type
type
Yes
String
args
Yes
Object
For details about the data structure of the args field, see Table 8.
Table 8 Data structure of the args field Parameter
Mandatory
Type
securityGroups
No
String
How to obtain:
subnets
Yes
How to obtain:
- Create a YAML file for creating a workload (for example, a Deployment) and associating it with the new container network configuration. You can use any file name. In this example, the file name is deploy.yaml.
vim deploy.yaml
apiVersion: apps/v1 kind: Deployment metadata: name: nginx spec: replicas: 1 selector: matchLabels: app: nginx template: metadata: labels: app: nginx yangtse.io/network: "example" # Name of the custom container network configuration, which can be used to obtain all pods associated with the container network configuration by label annotations: yangtse.io/network: "example" # Name of the custom container network configuration spec: containers: - name: container-0 image: nginx:alpine resources: limits: cpu: 100m memory: 200Mi requests: cpu: 100m memory: 200Mi imagePullSecrets: - name: default-secret
- yangtse.io/network: name of the specified custom container network configuration. Only a container network configuration that is not associated with any namespace can be specified. Add this parameter to the label so that you can use the label to obtain all pods associated with this container network configuration.
The name of the custom container network configuration specified by yangtse.io/network is the same as the value of name in networkattachment-test.yaml.
- Create a Deployment.
kubectl create -f deploy.yaml
Information similar to the following is displayed:
deployment.apps/nginx created
Verify That a Container Network Configuration Is Associated with a Namespace or Workload
The following are steps to verify that a subnet and security group specified in the container network configuration have been associated with a workload. The steps for verifying that a container network configuration has been associated with a namespace are the same as those provided here.
- Verify that a subnet is associated.
- Check the IP address of a pod for a workload.
kubectl get pod -o wide
NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES nginx-85dbdb8c5d-ng5bb 1/1 Running 0 5d18h 192.168.60.5 ca50a5ae-e1ef-41c6-b3fc-6ebcd10a1e07 <none> <none>
- Log in to the Network Console. In the navigation pane, choose Virtual Private Cloud > Subnets. On the displayed page, click the subnet name.
- Click IP Addresses. If the IP address of the pod is displayed, the subnet is associated.
Figure 8 Viewing the subnet associated with a pod
- Verify that a security group is associated.
- Log in to Network Console. In the navigation pane, choose Access Control > Security Groups. On the displayed page, click the security group name.
- On the Associate Instances tab, click Supplementary Network Interfaces.
- View the private IP address of the pod in the Private IP Address column. If the private IP address of the pod is displayed, the security group is associated.
Figure 9 Viewing the IP address associated with a security group
You can delete a new container network configuration or view its YAML file.
Before deleting a container network configuration, delete all pods using the configuration, or the deletion will fail.
- Run the following command to filter out the pods that use the configuration (example is used as an example here) in the cluster:
kubectl get pod -A -o jsonpath="{range .items[?(@.metadata.annotations.cni\\.yangtse\\.io/network-status=='[{\"name\":\"example\"}]')]}{.metadata.namespace}{'\t'}{.metadata.name}{'\n'}{end}"
The name of each pod and the namespace associated with the configuration will be displayed.
- Delete the workload that each pod is running. The workload can be a Deployment, StatefulSet, Job, or CronJob.
kubectl delete deployment nginx
deployment.apps "nginx" deleted
- Delete the container network configuration.
kubectl delete -f networkattachment-test.yaml -n kube-system
networkattachmentdefinition.k8s.cni.cncf.io "example" deleted
