- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
CCE Container Storage (Everest)
Introduction
Everest is a cloud native container storage add-on that enables Kubernetes clusters to access cloud storage services through CSI.
In clusters of v1.27.5-r0, v1.28.3-r0, and later versions, this add-on is automatically configured by the system and does not need to be manually installed or updated.
Editing the Add-on
This add-on is installed by default. To modify its settings, perform the following steps:
- Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane on the left, choose Add-ons. Locate CCE Container Storage (Everest) on the right and click Edit.
- On the Edit Add-on page, modify the specifications.
Table 1 Everest specifications Parameter
Pods
Number of pods for the add-on.
High availability is not possible if there is only one pod. If an error occurs on the node where the pod runs, the add-on will fail.
CPU and memory quotas of the containers for running the add-on. The add-on contains the everest-csi-controller and everest-csi-driver components. For details, see Components.
- Modify the parameters.
Table 2 Everest parameters Parameter
csi_attacher_worker_threads
Number of worker nodes that can be concurrently processed by Everest for attaching EVS volumes. The default value is 60.
csi_attacher_detach_worker_threads
Number of worker nodes that can be concurrently processed by Everest for detaching EVS volumes. The default value is 60.
volume_attaching_flow_ctrl
Maximum number of EVS volumes that can be attached by the Everest add-on within 1 minute. The default value is 0, indicating that the performance of attaching EVS volumes is determined by the underlying storage resources.
cluster_id
Cluster ID
default_vpc_id
ID of the VPC to which the cluster belongs
disable_auto_mount_secret
Whether the default AK/SK can be used when an object bucket or parallel file system is mounted. The default value is false.
enable_node_attacher
Whether to enable the attacher on the agent to process the VolumeAttachment.
flow_control
This field is left blank by default. You do not need to configure this parameter.
over_subscription
Overcommitment ratio of the local storage pool (local_storage). The default value is 80. If the size of the local storage pool is 100 GiB, it can be overcommitted to 180 GiB.
project_id
ID of the project to which a cluster belongs
The performance of attaching a large number of EVS volumes has been optimized. The following parameters can be configured:- csi_attacher_worker_threads
- csi_attacher_detach_worker_threads
- volume_attaching_flow_ctrl
The preceding parameters are associated with each other and are constrained by the underlying storage resources in the region where the cluster is located. To attach a large number of volumes (more than 500 EVS volumes per minute), contact customer service and configure the parameters under their guidance to prevent the Everest add-on from running abnormally due to improper parameter settings.
- Click OK.
