Viewing Central Network Audit Logs
After CTS is enabled, it starts recording operations on cloud resources. You can view the operation records of the last seven days on the CTS console.
This section describes how you can query or export the operation records of the last seven days on the CTS console.
- Click
in the upper left corner to select a region and a project. - In the upper left corner of the page, click
to go to the service list. Under Management & Governance, click Cloud Trace Service. - In the navigation pane on the left, choose Trace List
- Specify filters as needed. The following filters are available:
- Trace Type: Set it to Management or Data.
- Trace Source, Resource Type, and Search By
Select filters from the drop-down list.
After you select Trace name for Search By, you also need to select a trace name.
After you select Resource ID for Search By, you also need to select or enter a resource ID.
After you select Resource name for Search By, you also need to select or enter a resource name.
- Operator: Select a specific operator (at the user level rather than the tenant level).
- Trace Status: Select All trace statuses, Normal, Warning, or Incident.
- Search time range: In the upper right corner, choose Last 1 hour, Last 1 day, or Last 1 week, or specify a custom time range.
- Click the arrow on the left of the required trace to expand its details.
- Click View Trace in the Operation column to view trace details.
