- What's New
- Function Overview
- Billing
- Getting Started
User Guide
Cloud Connection Operation Guide
- Permissions Management
- Cloud Connections
- Cross-Border Permits
- Network Instances
Bandwidth Packages
- Buying a Bandwidth Package
- Modifying a Bandwidth Package
- Binding a Bandwidth Package to a Cloud Connection
- Unbinding a Bandwidth Package from a Cloud Connection
- Changing a Pay-per-Use Bandwidth Package to a Yearly/Monthly Bandwidth Package
- Unsubscribing from a Yearly/Monthly Bandwidth Package
- Deleting a Pay-per-Use Bandwidth Package
- Managing Bandwidth Package Tags
- Inter-Region bandwidths
- Cross-Account Authorization
- Routes
- Monitoring and Auditing
- Quotas
- Central Network Operation Guide
Best Practices
- Connecting VPCs in the Same Region But in Different Accounts
- Connecting VPCs in Different Regions and Accounts
- Connecting On-Premises Data Centers and VPCs
- Connecting VPCs in Different Geographic Regions
- Connecting VPCs in Different Accounts
- Using a Cloud Connection and SNAT to Enable Private Networks to Access the Internet
- Using a Cloud Connection and DNAT to Enable the Internet to Access Private Networks
- Using a Cloud Connection and DNAT to Improve the Web Delivery Across Regions
- Using a Cloud Connection and a VPC Peering Connection to Connect VPCs Across Regions
API Reference
- Before You Start
- API Overview
- Calling APIs
API
Cloud Connections
- Creating a Cloud Connection
- Querying the Cloud Connection List
- Querying a Cloud Connection
- Updating a Cloud Connection
- Deleting a Cloud Connection
- Adding a Tag to a Cloud Connection
- Deleting a Tag from a Cloud Connection
- Querying the Tags Added to a Cloud Connection
- Querying Cloud Connections by Tag
- Network Instances
Bandwidth Packages
- Creating a Bandwidth Package
- Querying the Bandwidth Package List
- Querying a Bandwidth Package
- Updating a Bandwidth Package
- Deleting a Bandwidth Package
- Adding a Tag to a Bandwidth Package
- Deleting a Tag from a Bandwidth Package
- Querying the Tags of a Bandwidth Package
- Querying Bandwidth Packages by Tag
- Inter-Region Bandwidths
- Cloud Connection Routes
- Authorizations
Central Networks
- Creating a Central Network
- Querying the Central Network List
- Querying a Central Network
- Updating a Central Network
- Deleting a Central Network
- Adding a Tag to a Central Network
- Deleting a Tag from a Central Network
- Querying the Tags Added to a Central Network
- Querying Central Networks by Tag
- Adding a Central Network Policy
- Querying the List of Central Network Policies
- Applying a Central Network Policy
- Deleting a Central Network Policy
- Querying the Changes Between the Current Policy and an Applied Policy
Central Network Attachments
- Adding a Global DC Gateway to a Central Network
- Querying the List of Global DC Gateways on a Central Network
- Querying a Global DC Gateway on a Central Network
- Updating a Global DC Gateway on a Central Network
- Adding a Route Table of an Enterprise Router as an Attachment on a Central Network
- Querying the List of Enterprise Router Route Tables on a Central Network
- Querying an Enterprise Router Route Table on a Central Network
- Updating an Enterprise Router Route Table on a Central Network
- Querying the List of Central Network Attachments
- Removing an Attachment from a Central Network
- Central Network Connections
- Site Network Management
- Site-to-Site Connection Management
- Cloud Connection Quotas
- Central Network Quotas
- Central Network Capabilities
- Site Network Quotas
- Site Network Capabilities
- Specifications
Global Connection Bandwidths
- Querying the Global Connection Bandwidth List
- Creating a Global Connection Bandwidth
- Querying a Global Connection Bandwidth
- Updating a Global Connection Bandwidth
- Deleting a Global Connection Bandwidth
- Binding a Global Connection Bandwidth to an Instance
- Unbinding a Global Connection Bandwidth from an Instance
- Querying the List of Global Connection Bandwidths That Meet the Binding Conditions
- Querying the Tenant Configuration of a Global Connection Bandwidth
- Querying the Line Specification List
- Querying the Site List
- Querying the Line Grade List
Global Connection Bandwidth Tag Management
- Querying a Global Connection Bandwidth Tag in an Account
- Adding a Tag to a Global Connection Bandwidth
- Deleting a Tag from a Global Connection Bandwidth
- Adding Tags to a Global Connection Bandwidth
- Deleting Tags from a Global Connection Bandwidth
- Querying the Number of Global Connection Bandwidth Tags in an Account
- Querying the List of Global Connection Bandwidths in an Account
- Querying All Global Connection Bandwidth Tags in an Account
Cloud Connections
- Appendix
- Historical APIs
- SDK Reference
Popular Questions
- How Do I Configure Cloud Connect?
- What Can I Do If Cross-Region Network Communications Fail?
- What Tools Can I Use to Test Network Connectivity After All Configurations Are Complete?
- What Can I Do If There Is a Route Conflict When I Load a Network Instance to a Cloud Connection?
- How Can I Modify the Bandwidth of a Purchased Bandwidth Package?
- Do I Need to Create Another Cloud Connection If Network Instances in One Region Need to Communicate with Network Instances in Two Other Regions That Have Already Been Loaded to a Cloud Connection?
- Why Do I Need Cloud Connect If the Network Latency Is the Same as on the Internet?
General Consulting and Service Use
- What Can I Do with Cloud Connect?
- What Are the Differences Between Cloud Connect and VPC Peering?
- What Network Instance Types Does Cloud Connect Support?
- How Many Bandwidth Packages Can I Bind to a Cloud Connection?
- Are the Uplink and Downlink Rates of the Configured Inter-Region Bandwidth the Same?
- Are There Any Limits on the Traffic for Cross-Region Network Communications?
- What Are the Metrics for Traffic Monitoring?
- What Are the Restrictions of Using Cloud Connect?
- Where Can I Add Routes for a Cloud Connection on the Management Console?
- Do I Need to Bind an EIP to Each ECS in the VPCs Connected over a Cloud Connection?
- Will the Modified Inter-Region Bandwidth Take Effect Immediately?
- How Can I Modify Inter-Region Bandwidth?
- Are Network Circuits Physically Isolated?
- Is Cloud Connect an Out-Of-The-Box Service?
- How Can Cloud Connect Offer High Availability?
Console Operations
- How Can I Apply for a Cross-Border Permit?
- What Tool Can I Used to Test the Bandwidth Rate of a Cloud Connection?
- Bandwidth Packages
Bandwidth, Latency and Packet Loss
- How Can I Troubleshoot Network Connectivity for a Hybrid Cloud Built Using Cloud Connect and Direct Connect?
- Do I Need a Bandwidth Package for Testing Network Connectivity?
- How Can I Modify an Inter-Region Bandwidth?
Cross-Border Permit
- Why Do I Need a Cross-Border Permit?
- Who Approves Cross-Border Permits?
- When Would I Need to Apply for a Cross-Border Permit?
- How Long Will a Cross-Border Permit Be Approved?
- Why Is Additional Real-Name Authentication Required After I Have Completed Huawei Cloud Real-Name Authentication?
- Can I Modify the Content of the Cloud Connect Cross-Border Circuit Service Agreement?
- Can I Download the Materials for My Cross-Border Permit Application on the Console After I Delete Them from My PC?
- Does Huawei Cloud Need to Sign and Stamp the Seal on the Materials for Cross-Border Permit Application?
- Networking and Cloud Connect Scenarios
- Does the Other User Need to Buy a Bandwidth Package If I Want to Load This Other User's VPCs to My Cloud Connection?
- Does the Other User Need to Create a Cloud Connection If I Want to Load This Other User's VPCs to My Cloud Connection?
- How Do I Load VPCs Across Accounts?
- Can a VPC Be Loaded to More than One Cloud Connection?
- Permissions
- Monitoring
- Quotas
Popular Questions
On this page
Show all
Help Center/
Cloud Connect/
User Guide/
Central Network Operation Guide/
Monitoring and Auditing/
Using CTS to Record Key Operations on Central Networks
