Monitoring Metrics Supported by Global Connection Bandwidths
Overview
The table describes monitoring metrics reported by global connection bandwidths to Cloud Eye as well as their namespaces and dimensions. You can use the management console to query the metrics of the monitored objects and alarms generated for global connection bandwidths.
Namespace
SYS.GCB
Metrics
| ID | Metric | Description | Value Range | Unit | Monitored Object (Dimension) | Monitoring Interval (Raw Data) |
| network_bytes | Network Traffic | Traffic of a global connection bandwidth in a measurement period | ≥ 0 | Byte | Global connection bandwidth | 1 minute |
| network_bandwidth | Network Bandwidth | Actually used global connection bandwidth in a measurement period | ≥ 0 | bit/s | Global connection bandwidth | 1 minute |
| network_bandwidth_usage | Network Bandwidth Usage | Utilization of a global connection bandwidth in a measurement period | ≥ 0 | % | Global connection bandwidth | 1 minute |
Dimensions
| Key | Value |
| gcb_id | Global connection bandwidth |
