Creating an Alarm Rule
This section describes how to create alarm rules and notifications for cloud connections.
The alarm function provides the alarm service for monitoring data. By creating alarm rules, you define how the alarm system checks monitoring data and sends alarm notifications when monitoring data meets alarm policies.
After creating alarm rules for important metrics, you can timely know metric data exceptions and quickly rectify the faults.
- Go to the Alarm Rules page.
- Click Create Alarm Rule or modify an existing alarm rule.
- Configuring the parameters and then click Create.
After the alarm rule is set, the system automatically notifies you when an alarm is triggered.
