Cloud Connection Metrics
The table describes monitored metrics reported by cloud connections to Cloud Eye as well as their namespaces and dimensions. You can use the management console to query the metrics of the monitored objects and alarms generated for cloud connections.
Namespace
SYS.CC
Metrics
ID |
Metric |
Description |
Value Range |
Unit |
Conversion Rule |
Monitored Object (Dimension) |
Monitoring Interval |
network_incoming_bits_rate |
Network Incoming Bandwidth |
Bit rate for inbound data to a region from another region of a cloud connection |
≥ 0 |
bits/s |
1000 (SI) |
Inter-region bandwidth |
1 minute |
network_outgoing_bits_rate |
Network Outgoing Bandwidth |
Bit rate for outbound data from a region to another region of a cloud connection |
≥ 0 |
bits/s |
1000 (SI) |
1 minute |
network_incoming_bytes |
Network Incoming Traffic |
Number of bytes for inbound data to a region from another region of a cloud connection |
≥ 0 |
bytes |
1024 (IEC) |
1 minute |
network_outgoing_bytes |
Network Outgoing Traffic |
Number of bytes for outbound data from a region to another region of a cloud connection |
≥ 0 |
bytes |
1024 (IEC) |
1 minute |
network_incoming_packets_rate |
Network Incoming Packet Rate |
Packet rate for inbound data to a region from another region of a cloud connection |
≥ 0 |
packets/s |
N/A |
1 minute |
network_outgoing_packets_rate |
Network Outgoing Packet Rate |
Packet rate for outbound data from a region to another region of a cloud connection |
≥ 0 |
packets/s |
N/A |
1 minute |
network_incoming_packets |
Network Incoming Packets |
Number of packets for inbound data to a region from another region of a cloud connection |
≥ 0 |
packets |
N/A |
1 minute |
network_outgoing_packets |
Network Outgoing Packets |
Number of packets for outbound data from a region to another region of a cloud connection |
≥ 0 |
packets |
N/A |
1 minute |
network_bandwidth_usage |
Network Bandwidth Usage |
Utilization of an inter-region bandwidth assigned to a cloud connection |
0-100 |
N/A |
1 minute |
network_bandwidth |
Network Bandwidth |
Inter-region bandwidth of a cloud connection |
≥ 0 |
bits/s |
1000 (SI) |
1 minute |
Metrics in certain regions are monitored every 5 minutes. Check the console for the exact monitoring interval.
Dimensions
Key |
Value |
cloud_connect_id |
Cloud connection ID |
bwp_id |
Bandwidth package ID |
region_bandwidth_id |
Inter-region bandwidth ID |
If a monitored object has multiple dimensions, all dimensions are mandatory when you use APIs to query the metrics.
- Query a single metric:
dim.0=cloud_connect_id%2Ca92ab2f75d844dbebbc3fcc7871d1136&dim.1=bwp_id%2C625db750db7b1447d0c9d1a447c11903&dim.2=region_bandwidth_id%2Ce2cc9dc0b4954fbbaf1299f2727fe1ca.
- Query multiple metrics:
"dimensions": [ { "name": "cloud_connect_id", "value": "a92ab2f75d844dbebbc3fcc7871d1136" }, { "name": "bwp_id", "value": "625db750db7b1447d0c9d1a447c11903" }, { "name": "region_bandwidth_id", "value": "e2cc9dc0b4954fbbaf1299f2727fe1ca" } ],
