Updated on 2026-03-06 GMT+08:00
Authorizing Network Instances
Allow another account to use network instances in your account or load network instances authorized by another account to the cloud connection in your account.
  • You can share your network instances with other accounts, or have them share theirs with you.
  • Only VPCs can be authorized. A VPC can only be loaded to one cloud connection.
Authorizing Another Account to Use Network Instances in Your Account
You can grant other accounts the permissions to load the VPCs in your account to their cloud connection.
  1. Go to the Cross-Account Authorization page.
  2. On the Network Instances Authorized by Me tab, click Authorize Network Instance.
  3. Configure the parameters based on Table 1.
    Figure 1 Cross-account authorization
    Table 1 Parameters for cross-account authorization
    Example Value
    Region
    Specifies the region where the VPC is located.
    CN-Hong Kong
    VPC
    Specifies the VPC you want to authorize.
    VPC-A
    Peer Account ID
    Specifies the ID of the peer account.
    To obtain the account ID, log in to the management console using the peer account. In the drop-down list of the username in the upper right corner, click My Credentials. On the API Credentials page, copy the account ID.
    Peer Cloud Connection ID
    Specifies the ID of the peer cloud connection that the VPC is to be loaded to.
    For details about how to obtain the cloud connection ID, see Viewing a Cloud Connection.
    Remarks
    Provides supplementary information about cross-account authorization.
  4. Click OK.
Loading Network Instances in Other Accounts to the Cloud Connection in Your Account
You can load the VPCs in other accounts to your cloud connection so that your VPCs can communicate with these authorized VPCs.
  2. Click the Network Instances Authorized to Me tab.
  3. Locate the network instance and click Load to Cloud Connection in the Operation column.
  4. Configure the parameters based on Table 2.
    Table 2 Parameters for loading a VPC to a cloud connection
    Example Value
    Cloud Connection ID
    Specifies the ID of the cloud connection to which the VPC you want to load.
    Region
    Specifies the region where the VPC you want to connect is located.
    CN-Hong Kong
    Instance Type
    Specifies the type of the network instance you can load. Only VPCs can be loaded.
    VPC
    Peer VPC
    Specifies the ID of the VPC to be loaded.
    For details about how to obtain the VPC ID, see Obtaining a VPC ID.
    VPC CIDR Block
    Specifies the subnets of the VPC you want to load and the custom CIDR blocks.
  5. Click OK.
    You can view the loaded VPC on the Network Instances tab. For details, see Managing Network Instances.
