Help Center/
      Cloud Connect/
        User Guide/
        Cloud Connection Operation Guide/
        Inter-Region Bandwidths/
      Viewing Monitoring Data of an Inter-Region Bandwidth
        Updated on 2025-04-16 GMT+08:00
You can view the real-time monitoring data of an inter-region bandwidth to evaluate the network quality.
- Go to the Cloud Connections page.
 - Click the name of the cloud connection to go to the Basic Information tab.
 - Click the Inter-Region Bandwidths tab.
 - Locate the inter-region bandwidth and click the icon in the Monitoring column to view the metrics of the corresponding period, for example, metrics of the last hour, 3 hours, or 12 hours.
   Parent topic: Inter-Region Bandwidths
