Managing Bandwidth Package Tags
A tag is an identifier of a bandwidth package and consists of a key and a value.
You can perform the following operations to manage your bandwidth package tags:
- You can add up to 20 tags to a bandwidth package.
- If a predefined tag has been created on TMS, you can directly select the corresponding tag key and value.
For details about predefined tags, see Predefined Tags.
Adding a Tag
Add a tag to an existing bandwidth package.
- Go to the Bandwidth Packages page.
- Locate the bandwidth package and click its name to go to the details page.
- Click the Tags tab.
- Click Add Tag.
- In the displayed dialog box, enter a key and a value.
Table 1 describes the tag key and value requirements.
Table 1 Tag naming requirements Parameter
Requirements
Example Value
Tag key
For each resource, each tag key must be unique, and each tag key can only have one tag value.
- Cannot be left blank.
- Can contain no more than 128 characters.
- Can contain letters in any language, digits, spaces, underscores (_), periods (.), colons (:), equal signs (=), plus signs (+), minus signs (-), and at signs (@).
- Cannot start with _sys_ or a space or end with a space.
bandwidthpackage_key1
Tag value
- Can be left blank.
- Can contain no more than 255 characters.
- Can contain letters in any language, digits, spaces, underscores (_), periods (.), colons (:), slashes (/), equal signs (=), plus signs (+), minus signs (-), and at signs (@).
- Cannot start or end with a space.
bandwidthpackage-01
- Click OK.
Editing a Tag
Modify the value of a tag added to a bandwidth package.
- Locate the tag and click Edit in the Operation column.
- In the displayed dialog box, modify the tag value as needed.
- Click OK.
Deleting a Tag
Delete a tag from a bandwidth package.
Deleted tags cannot be recovered.
- Locate the tag and click Delete in the Operation column.
