Help Center/ Cloud Connect/ User Guide/ Cloud Connection Operation Guide/ Bandwidth Packages/ Managing Bandwidth Packages/ Changing a Pay-per-Use Bandwidth Package to a Yearly/Monthly Bandwidth Package
Updated on 2025-04-16 GMT+08:00
Currently, pay-per-use billing is only for trial use. After this option is enabled, you can change a pay-per-use bandwidth package to a yearly/monthly bandwidth package.
Your application for enabling the pay-per-use billing mode has been approved, and you have purchased a pay-per-use bandwidth package.
  1. Go to the Bandwidth Packages page.
  2. Locate the bandwidth package and click More > Change Billing Mode.
  3. In the displayed dialog box, click OK.
  4. On the Change Subscription page, set the required duration and click Pay.
  5. On the displayed page, select a payment method and click OK.
