Updated on 2025-04-16 GMT+08:00
Changing the Capacity of a Bandwidth Package
You can modify the capacity of a bandwidth package you have purchased. You can increase or decrease the bandwidth. In the following steps, increasing the bandwidth is used as an example.
  • Increasing the bandwidth
    Pay for the increased bandwidth. The new bandwidth will take effect after payment is complete.
  • Decreasing the bandwidth
    If you decrease the bandwidth, the system will refund the overpayment to your account. The new bandwidth takes effect immediately.
The following procedure use bandwidth increase as an example.
  1. Go to the Bandwidth Packages page.
  2. Locate the bandwidth package and click Modify Bandwidth in the Operation column.
  3. In the displayed dialog box, select Upgrade and click Continue.
  4. On the Modify Bandwidth page, set the new bandwidth and click OK.
  5. Confirm the bandwidth package information and click Submit.
  6. Select a payment method and click OK.
  • Modifying the bandwidth does not interrupt services.
  • If bandwidth package expires in less than 24 hours, you cannot increase or decrease the bandwidth.
