Managing Cloud Connection Tags
A tag is the identifier of a cloud connection and consists of a key and a value.
You can perform the following operations to manage your cloud connection tags:
- You can add up to 20 tags to a cloud connection.
 - If you have configured tag policies for Cloud Connect, add tags to cloud connections based on the tag policies. If you add a tag that does not comply with the tag policies, cloud connections may fail to be created. Contact your administrator to learn more about tag policies.
     If a predefined tag has been created on TMS, you can directly select the corresponding tag key and value.
For details about predefined tags, see Predefined Tags.
Adding a Tag
Add a tag to an existing cloud connection.
- Go to the Cloud Connections page.
 - Click the name of the cloud connection to go to the Basic Information tab.
 - Click the Tags tab.
 - In the displayed dialog box, enter a key and a value.
Table 1 describes the tag key and value requirements.
Table 1 Tag naming requirements Parameter
Requirements
Example Value
Tag key
For each resource, each tag key must be unique, and each tag key can only have one tag value.
- Cannot be left blank.
 - Can contain no more than 128 characters.
 - Can contain letters in any language, digits, spaces, underscores (_), periods (.), colons (:), equal signs (=), plus signs (+), minus signs (-), and at signs (@).
 - Cannot start with _sys_ or a space or end with a space.
cc_key1
Tag value
- Can be left blank.
 - Can contain no more than 255 characters.
 - Can contain letters in any language, digits, spaces, underscores (_), periods (.), colons (:), slashes (/), equal signs (=), plus signs (+), minus signs (-), and at signs (@).
 - Cannot start or end with a space.
cc-01
 - Click OK.
Editing a Tag
Modify the value of a tag added to a cloud connection.
 - Locate the tag and click Edit in the Operation column.
 - Enter a new value.
 - Click OK.
Deleting a Tag
Delete a tag from a cloud connection.
   Deleted tags cannot be recovered.
 - Locate the tag and click Delete in the Operation column.
 - Click OK.
