Binding or Unbinding a Bandwidth Package to and from a Cloud Connection
This section describes how to bind or unbind a bandwidth package to and from a cloud connection.
Currently, Cloud Connect provides only 1 kbit/s of bandwidth for testing network connectivity. If no bandwidth package is bound, cross-region networks cannot be connected.
- Multiple bandwidth packages with different billing modes can be bound to a cloud connection.
- A cloud connection can only have one bandwidth package bound if the geographic region and billing mode of the bandwidth packages are the same.
Binding a Bandwidth Package to a Cloud Connection
- Go to the Cloud Connections page.
- Click the name of the cloud connection to go to the Basic Information tab.
- Click the Bandwidth Packages tab.
- Click Bind Bandwidth Package and select the bandwidth package to be bound.
If you have not purchased a bandwidth package, click Buy Bandwidth Package and then select a cloud connection. For details about how to purchase a bandwidth package, see Buying a Bandwidth Package.
Unbinding a Bandwidth Package from a Cloud Connection
If you do not need a bandwidth package, you can unbind it from the cloud connection.
Before unbinding a bandwidth package, delete all inter-region bandwidths assigned based on the bandwidth package. For details about how to delete an inter-region bandwidth, see Deleting an Inter-Region Bandwidth.
- Locate the bandwidth package you want to unbind and click Unbind in the Operation column.
