Managing Cross-Cloud Replication Credentials
You can edit the name or access key (AK/SK) of a cross-cloud replication credential. If you no longer need the cross-cloud replication credential, you can delete it. This section describes how to edit, delete, and export a cross-cloud replication credential.
- If a cross-cloud replication policy is scheduled to run while its associated credential's name or target cloud AK/SK is being edited, the replication may fail. The system will retry automatically.
- Deleted credentials cannot be recovered.
- After you delete the credentials that have been used to create cross-cloud replication policies, cross-cloud replication will become unavailable.
Modifying Cross-Cloud Replication Credentials
- Log in to the CBR console.
- In the upper left corner, click
and select a region. - Click
and choose Storage > Cloud Backup and Recovery. Choose Settings.
- On the Cross-Cloud Replication Credentials page, locate the target cross-cloud replication credential and click Edit in the Operation column. Modify the credential by referring to Table 1.
Only the credential name, description, and access key (AK/SK) can be modified.
- Select Modify Access Key (AK/SK) to modify the access key (AK/SK).
- Select I acknowledge the risks and confirm that I want to modify the credentials.
- Click OK.
Deleting Cross-Cloud Replication Credentials
- On the Cross-Cloud Replication Credentials page, locate the target cross-cloud replication credential and click Delete in the Operation column.
- In the displayed dialog box, confirm the information, type "DELETE", and click OK. The cross-cloud replication credential will be deleted.
- Go back to the Cross-Cloud Replication Credentials page and confirm that the credential has been deleted.
- (Optional) Select multiple cross-cloud replication credentials and click Delete above the credential list to delete them in a batch.
Exporting Cross-Cloud Replication Credentials
- On the Cross-Cloud Replication Credentials page, click Export above the list to export credentials in a batch.
- Download the exported Excel file from the download directory.
