Database Server Backup
Overview
There are three types of backups in terms of backup consistency:
- Inconsistent backup: Files and disks are backed up at different points in time. CBR cloud server backup uses the consistency snapshot technology for disks to protect data of ECSs and BMSs. If you back up multiple EVS disks separately, the backup time points of the EVS disks are different. As a result, the backup data of the EVS disks is inconsistent.
- Crash-consistent backup: A crash-consistent backup captures all data on disks at the time of the backup and does not capture data in memory or any pending I/O operations. Although it cannot ensure application consistency, disks are checked by chkdsk upon operating system restart to restore damaged data, and undo logs are used by databases to keep data consistent.
- Application-consistent backup: An application-consistent backup captures data in memory or any pending I/O operations and allows applications to achieve a quiescent and consistent state.
Figure 1 compares these backup types in detail.
CBR supports both crash-consistent backup (also called cloud server backup) and application-consistent backup (also called database server backup).
Crash-consistent backup does not back up data in memory or pending I/O operations and cannot be used to restore applications. If your server is running a MySQL or SAP HANA database, you can use application-consistent backup. An application-consistent backup captures application information both in memory and pending I/O operations and can be used to quickly restore applications.
Differences Between Database Server Backup and Cloud Server Backup
| Item | Database Server Backup | Cloud Server Backup |
| Object | Cloud servers with MySQL or SAP HANA database deployed | Cloud servers without databases |
| Granularity | Cloud server | Cloud server |
| Vault | Server backup vault | Server backup vault |
| Recommended scenario | Data from cloud servers and associated databases (for example, MySQL or SAP HANA) needs to be backed up. In case of an error, all data and application configurations must be restored. | Only data of cloud servers needs to be backed up. Such data needs to be restored in case of an error. If you use cloud server backup to back up database servers such as MySQL or SAP HANA database servers, certain database configurations may not be fully restored from the backups. This can result in startup issues when the database is restarted. |
There are two types of vaults to store server backups. Those store backups of non-database servers are common server backup vaults, and those store backups of database servers are database server backup vaults.
OSs Supporting the Agent
Table 2 lists the OSs that can run the Agent. Only Windows OSs in English can have the Agent installed.
| Database | OS | Supported Versions |
| SQL Server 2008 | Windows | Windows Server 2012, 2012 R2, 2019 for x86_64 |
| SQL Server 2012 | Windows | Windows Server 2012, 2012 R2, 2019 for x86_64 |
| SQL Server 2019 | Windows | Windows Server 2019 for x86_64 |
| SQL Server 2014/2016/EE | Windows | Windows Server 2016 Datacenter for x86_64 |
| MySQL 5.5/5.6/5.7 | Red Hat | Red Hat Enterprise Linux 6 and 7 for x86_64 |
| SUSE | SUSE Linux Enterprise Server 12, 15 SP1, 15 SP2 for x86_64 | |
| CentOS | CentOS 6 and 7 for x86_64 | |
| EulerOS | Euler OS 2.2 and 2.3 for x86_64 | |
| HANA 1.0/2.0 | SUSE | SUSE Linux Enterprise Server 12 for x86_64 |
For Windows servers, ensure that Volume Shadow Copy is running properly. Otherwise, the backup will fail.
For databases that are not in the compatibility list, you can create a custom script to back up the database server by referring to Using a Custom Script to Implement Application-Consistent Backup in the Cloud Backup and Recovery Best Practices.
- Change the security group: Before performing a database server backup task, change the security group of the server you want to back up.
- Install the Agent: Before backing up the target server, you must both change the security group and install the Agent. These two operations can be performed in any order, but ensure that both are completed prior to initiating the backup.
- Create a database server backup: After creating a server backup vault for storing database server backups, associate it with the desired database server and then create a database server backup.
- Modify or compile a custom script: After backing up a database server on the CBR console, modify or compile a custom script on the database of the server. For details, see Using a Custom Script to Implement Database Server Backup.
- Verify the backup result: After the backup is performed, verify that the backup succeeds. For details, see Verifying the Database Server Backup.
- Use the database server backup to restore server data. After restoration, the database applications and data will return to the exact state they were in at the time the backup was created. For details, see Restoring from a Cloud Server Backup.
