Updated on 2026-01-22 GMT+08:00
Replacing CA Certificates
A CA certificate is a digital file signed and issued by an authentication authority. It contains the public key, information about the owner of the public key, information about the issuer, validity period, and certain extension information. It is used to set up a secure information transfer channel between the Agent and the server.
If the CA certificate does not comply with the security requirements or has expired, replace it for security purposes.
  • The username and password for logging in to an ECS have been obtained.
  • A new CA certificate is ready.
Replacing CA Certificates in Linux
  1. Log in the Linux server running the Agent.
  2. Prevent logout due to system timeout:
    TMOUT=0
  3. Switch to user rdadmin:
    su - rdadmin
  4. Go to the path where the Agent start/stop script is stored:
    cd /home/rdadmin/Agent/bin
  5. Stop the Agent:
    sh agent_stop.sh
  6. Go to the path where the CA certificate is stored:
    cd /home/rdadmin/Agent/bin/nginx/conf
  7. Delete the existing CA certificate:
    rm bcmagentca.crt
  8. Copy the new CA certificate file into the /home/rdadmin/Agent/bin/nginx/conf directory and rename the file bcmagentca.crt.
  9. Change the owner of the CA certificate:
    chown rdadmin:rdadmin bcmagentca.crt
  10. Modify the permissions on the CA certificate:
    chmod 400 bcmagentca.crt
  11. Go to the path where the Agent start/stop script is stored:
  12. Start the Agent:
    sh agent_start.sh
Replacing CA Certificates in Windows
  1. Log in to the ECS with the Agent installed.
  2. Go to the Installation path\bin directory.
  3. Run the agent_stop.bat script to stop the Agent.
  4. Go to the Installation path\nginx\conf directory.
  5. Delete the bcmagentca.crt certificate file.
  6. Copy the new CA certificate file into the Installation path\nginx\conf directory and rename the file bcmagentca.crt.
  7. Go to the Installation path\bin directory.
  8. Run the agent_start.bat script to start the Agent.
