On this page
Creating a Backup Policy
Updated on 2025-01-17 GMT+08:00
A backup policy allows CBR to automatically back up vaults at specified times or intervals. Periodic backups can be used to restore data quickly against data corruption or loss.
To implement periodic backups, you need a backup policy first. You can use the default backup policy or create one as needed.
Peak hours of the backup service are from 22:00 to 08:00, during which there may be delays. So you are advised to evaluate your service types and schedule backups in discrete time periods.
  • Backup policies can be applied to the following types of vaults: server backup vaults, disk backup vaults, SFS Turbo backup vaults
  • A backup policy must be enabled before it can be used for periodic backups.
  • A maximum of 32 backup policies can be created in each account.
  • When a backup time and a replication time are both configured, ensure that replication starts after backup is complete. Or, replication may fail.
  • When expired backups are deleted, automatic backups will be deleted, but manual backups will not.
  • Only servers in the Running or Stopped state and disks in the Available or In-use state can be backed up.
  • CBR by default performs a full backup for a resource in the initial backup and incremental backups in subsequent backups.
  • The minimum interval between two full backups is 1 day.
  1. Log in to the CBR console.
    2. Click in the upper left corner and select a region.
    3. Click and choose Storage > Cloud Backup and Recovery.
  2. Choose Policies in the left navigation pane and click the Backup Policies tab. In the upper right corner, click Create Policy. See Figure 1.
    Figure 1 Creating a backup policy
  3. Set the backup policy parameters. Table 1 describes the parameters.
    Table 1 Backup policy parameters
    Example Value
    Type
    Select a policy type. In this section, we select the backup policy.
    Backup policy
    Name
    Backup policy name
    A name must contain 1 to 64 characters including digits, letters, underscores (_), or hyphens (-).
    backup_policy
    Status
    Whether to enable the backup policy.
    Only after a backup policy is enabled and applied will CBR automatically backs up the vault resources and deletes expired backups.
    Backup Frequency
    Select a backup frequency.
    • Weekly
      Specifies on which days of each week the backup task will be executed. You can select multiple days.
    • Day based
      Specifies the interval (every 1 to 30 days) for executing the backup task.
    Every day
    If you select day-based backup, the first backup is supposed to be executed on the day when the backup policy is created. If the execution time on the day you create the backup policy has passed, the first backup will be executed in the next backup cycle.
    It is recommended that backups be performed during off-peak hours or when no services are running.
    Execution Time
    Execution time
    Backups can be scheduled at the beginning of each hour, and you can select multiple hours.
    NOTICE:
    • There may be a time difference between the scheduled backup time and the actual backup time.
    • If a large amount of data needs to be backed up, you are advised to make backup less frequent to prevent the system from skipping any execution time.
      For example, a disk is scheduled to be backed up at 00:00, 01:00, and 02:00. A backup task starts at 00:00. Because a large amount of incremental data needs to be backed up or a heap of backup tasks are executed at the same time, this backup task takes 90 minutes and completes at 01:30. CBR performs the next backup at 02:00. In this case, only two backups are generated in total, one at 00:00, and the other at 02:00.
    • The execution times refer to the local times of clients, not the time zone and times of the region.
    00:00, 02:00
    • It is recommended that backups be performed during off-peak hours or when no services are running.
    • Peak hours of the backup service are from 00:00 to 06:00, during which there may be scheduling delays. So you are advised to evaluate your service types and schedule backups outside of the backup peak hours.
    Full Backup
    Whether to perform periodic full backups.
    • Enable
      Enabling full backup improves your data reliability, but full backups will use more storage space.
      Configure a full backup frequency. The value ranges from 0 to 100. Value 0 means that a full backup will be performed in every backup task.
    • Do not enable
      CBR will perform incremental backups after the first backup.
      NOTICE:
      • A full backup usually takes a long period of time. If a full backup of a resource is in progress, other policy or manual backups of this resource will not be performed. You can back up data during off-peak hours.
      • When backups are kept by quantity, full backups can be performed only when the full backup frequency configured is less than the number of retained backups.
      • If full backup is not enabled, to ensure data security, a full backup is performed after 365 incremental backups by default.
    7
    Retention Rule
    Rule that specifies how backups will be retained
    • Time period
      You can choose to retain backups for one month, three months, six months, one year, or for any desired number (2 to 99999) of days.
    • Backup quantity
      You can set the maximum number of backups to retain for each resource. The value ranges from 2 to 99999.
    • Advanced Options
      You can also set long-term retention rules with advanced options. Long-term retention rules and quantity-based retention rules will be both applied.
      • Day-based: 0–100
      • Weekly: 0–100
      • Monthly: 0–100
      • Yearly: 0–100
      A resource may be backed up multiple times in a day. If day-based backup is configured, only the most recent backup of that day is retained. If you set Day-based to 5, the most recent backup of each of the last five days that have backups generated will be retained. That is, a total of five backups are retained. If there are more than five backup replicas, the system automatically deletes the earliest backup replicas. If day-based, weekly, monthly, and yearly retention rules are all configured, all the rules will apply and the union set of backups will be retained. For example, if Day-based is set to 5 and Weekly to 1, five backups will be retained. The long-term retention rule and the quantity-based retention rule both apply.
    • Permanent
      • The system automatically deletes the earliest and expired backups every other day to avoid exceeding the maximum number of backups to retain or retaining any backup longer than the maximum retention period.
      • Expired backups are not deleted right after they are expired. They will be deleted during 08:00 to 20:00 in batches. For example, if a backup expired at 20:00 on November 23, 2024, it will be deleted during 08:00 to 20:00 on November 24, 2024. In this way, backup data can be deleted during off-peak hours.
      • The retention rules apply only to auto-generated backups, but not manual backups. Manual backups need to be deleted manually.
      • If a backup is used to create an image, the backup will not be deleted by the retention rule. It will be forcibly retained. If you delete the image created from the backup, the backup will be retained based on the original retention rule applied. (If the backup expires or is not within the most recent backups specified in the retention rule, CBR will automatically delete the backup.)
      • A maximum of 10 backups are retained for failed periodic backup tasks. They are retained for one month and can be deleted manually.
      • If a backup has been created and the next backup task is in progress, CBR will not allow you to delete the most recent backup created. You can delete the backup only after the backup task is complete.
    Select Backup quantity and set to keep 3 backups. In addition, select Advanced Options and set to keep the most recent backup from each of the last two weeks. If today is the 30th of a month, see the execution of this policy in Figure 3.
    • Dates with a time indicate the days that have backups generated
    • Dates with the time in gray indicate that the backups have been deleted.
    • Dates with the time in green indicate that the backups are retained.
    If the weekly retention rule in advanced options is not configured, only the backups generated on the 25th, 26th, and 29th are retained.
    Figure 2 Retention rule with advanced options configured
    Figure 3 The execution of the retention rule
    More frequent backups create more backups or retain backups for a longer time, protecting data to a greater extent but occupying more storage space. Set an appropriate backup frequency as needed.
  4. Click OK.
    You can locate the desired vault and choose More > Apply Backup Policy to apply the policy to the vault. Then you can view the applied policy on the vault details page. After the policy is applied, data will be periodically backed up to the vault based on the policy.
Example
At 10:00 a.m. on Monday, a user sets a backup policy for their vault to instruct CBR to execute a backup task at 02:00 a.m. every day and retain a maximum of three backups. As of 11:00 a.m. on Saturday, three backups will be retained, which are generated on Thursday, Friday, and Saturday. The backups generated at 02:00 a.m. on Tuesday and Wednesday have been automatically deleted.
