Updated on 2026-03-12 GMT+08:00
Uninstalling the Agent
This section describes how to uninstall the Agent when application-consistent backup is no longer needed.
The username and password for logging in to the ECS have been obtained.
Uninstalling the Agent for Linux
  1. Log in to the ECS and run the su -root command to switch to user root.
  2. In the home/rdadmin/Agent/bin directory, run the following command to uninstall the Agent. Figure 1 displays an example. If the word successfully in green is displayed, the Agent is uninstalled successfully.
    sh agent_uninstall_ebk.sh
    Figure 1 Agent uninstalled successfully from Linux
Uninstalling the Agent for Windows
  1. Log in to the ECS.
  2. In the Installation path/bin directory, double-click agent_uninstall_ebk.bat. The window for uninstalling the Agent is displayed.
    After the uninstallation is complete and successful, the window will be automatically closed.
    Figure 2 Agent uninstalled successfully from Windows
